New preamp for Father's Day
pearsall001
pearsall001 Posts: 5,297
edited June 2021 in 2 Channel Audio
I figured I'd treat myself. Picked up this beautiful beast! It's one heavy sucker.
Opera Audio Consonance Reference 1 tube pre.
The sound is incredible, deep & wide soundstage that even extends well out in front of the speakers.
Pin point imaging, lush voices both male & female (only two genders here folks)
I just picked it up Sat so I'm still gathering my impressionsmbd0dlxn9hh5.jpg
but so far she looks to be a keeper.
The combo with my Border Patrol DAC is a match made in heaven. It melts your arse right into the chair for hours on end.
Post edited by pearsall001 on
    pitdogg2 Posts: 27,066
    What tubes it take?
  • pearsall001
    It has 2-12AU7 & 1-EZ80.
    Tube rolling already... these sound pretty dang good so far.
    I knew one looked a little different 😉
    Clipdat Posts: 13,095
    Thanks for the guts shots! Enjoy your new toy. I like that wood top panel, very slick.
    tonyb Posts: 33,072
    Congrats on the new pre man. Nice to see you back into tubes after swearing them off from those Conrad Johnson days. Hard to beat that darn tube sound, rock on.
    mhardy6647 Posts: 35,047
    looks like a nice preamp :)
  • Milito
    Milito Posts: 2,003
    Congrats on your new preamp, hope you have many hours of enjoyment with it.
  • pearsall001
    tonyb wrote: »
    Older & wiser now! Lol! Man oh man you're going way back Tony. 🤠
  • pearsall001
    What tubes it take?
    I stand corrected on the tubes, they are not 12AU7 tubes.
    They are Electro-Harmonix 6H30 tubes (some call them "super tubes") Kinda like a tube inside a tube.
    I thought I called it wrong because these 6H30 tubes are huge, much larger than a 12AU7 tube.
    But I must say they do have a very mesmerizing tone so far & the pre isn't ever broken in yet. Will sound even better as it breaks in.
    I think Acoustic Research also use those Phil.
    After you said 12au7 I was still confused. Yes they are very different looking from any 12au I have ever seen.
    Thanks for the update.
  • pearsall001
    I believe BAT started using them back in 90's in their top of the line pre's, then AR along with Conrad Johnson started using them also.
    Rogue Audio uses them in their top of the line RP-9 pre.
    They are definitely different but man oh man do they deliver the sonic fire power.
    Most companies that use the 6H30 tubes generally use them in their top gear.
  • invalid
    invalid Posts: 1,458
    The nos 6h30p-dr tubes are really expensive.
  • pearsall001
    invalid wrote: »
    That they are! I've seen them go for upwards of $900.00 for a matched pair... yikes 😳
    Mine are stock Electro-Harmonix that sound absolutely divine.
    There are other rather reasonable 6H30 tubes to be had though if one gets the itch.
    I'm not close to climbing down that rabbit 🐇 hole just yet.
  • marvda1
    marvda1 Posts: 4,951
    try the sovtek 6h30-pi
    Puritan PSM156
    marvda1 wrote: »
    Supposedly it's the same tube from the same factory just different pins.
    EH gold
    Sovtek chrome
    Do you know differently Marv?
  • marvda1
    edited June 2021
    i have not compared but supposedly they sound different, could be the gold plating.
    here's an old discussion on the two.
    https://forum.audiogon.com/discussions/electro-harmonix-6h30pi-gold-vs-sovtek-6h30pi-eb
    Puritan PSM156
  • invalid
    You can roll the ez80/6v4 rectifier tube a lot cheaper.
  • pearsall001
    marvda1 wrote: »
    Thanks for the link. A very interesting discussion.
    I'm just wondering if the Sovtek would be more of a lateral move from the EH.
    I have to check to see if my EH are the gold plated (does that even make a difference?)
    When looking last night Kevin Deal upscale audio had this. Since I do not know this tube that is why I deferred to Marvin.
    There are two types of 6H30 tubes currently being produced. The Sovtek brand which have the chrome pins (listed here), and the Electro Harmonix Gold pin. They are the same tube from the same factory. Don’t get your panties in a bunch over which is better, as the gold plating is laid over the chrome plating. They are both terrific. What is most important is how they test. You guys already know that Upscale Audio is the only place that the Audio Research factory people give a thumbs up to. That’s because we actually have our power tubes matched properly and have the highest Gm, and that every small signal tube like the 6H30 is not just measured, but listened to in a special phono stage test circuit by using headphones. That, my friends, is the only way to get the blackest blacks in your system.
    Either way a lot of folks like the tube sit back and enjoy your new pre she's a beauty.
  • invalid
    tube testers can only show simple characteristic such as transconductance at only one operating point, curve tracers show you all operating parameters across all operating conditions – all at once.
  • pearsall001
    I've seen other videos with him but not the one you posted about with him giving insight on the 6h30 tube. I'll have to give him a listen.
    Thanks for the heads up on his video.
    Not to worry I am absolutely enjoying the new pre!
    I'll be honest and up front....I can't listen to Kevin too long his voice grinds that ear bone😆
  • pearsall001
    Too funny 😂 He is a character!
  • dromunds
    dromunds Posts: 10,129
    My Dodd battery preamp was designed for the 6H30 and the 6H30p-dr was highly recommended by Gary but I couldn't pull the trigger on it given the price even then. Gary said the 6DJ8 family would also work well and so I obtained NOS 1950's Amperex Holland 7308 D-getter, which now is pretty dang expensive itself. I would still like to try an NOS 6H30p-dr but keep cringing when I see the price.
  • pearsall001
    dromunds wrote: »
    Just pretend you're buying a new top notch PC or a new pair of speaker cables... the money some drop on those items makes the NOS 6h30p dr pale in comparison. 🤠
  • PSOVLSK
    PSOVLSK Posts: 5,384
