Need quality B+ and ground cable for amp in Harley touring bike
I know next to nothing when it comes to mobile electronics. If Radio Shack were here, I'd just go to them, but . . . they're not. So here goes:
I'm installing a Cervin Vega B52 amp (250W X2 into 2 ohms) and Infinity Kappa 6.5 inch speakers. According to a Harley forum, this is a decent combo for a mere 2 speaker setup.
I think I can handle the install with a little more research. But it's a little involved. Obviously the fairing comes off, but so does the gas tank and seat. Oh, and I've been told the plastic pods H-D uses to mount the speakers in are crap, so I also picked up custom metal brackets from Biketronics.
Being an audio enthusiast, I'd like descent power cables.
Any suggestions?
Any and all help is appreciated ...
TIA
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
    msg Posts: 10,532
    I don't know anything about wiring motorcycle stereo, but for all other electrics on my motorcycle, I installed a separate fuse panel. do you have that part covered?
    I think both MIT and Doug have motorcycle interconnects and speaker cables, and pretty sure @BlueFox posted once about Shunyata making power cables and a power regenerator for motorcycles, with a Harley specific kit. There may even be an SDA option with MC Dreadnought.
  • GlennDog
    GlennDog Posts: 3,158
    msg wrote: »
    All I need is a 25 amp in-line fuse within 18" of the battery
    msg wrote: »
    I'll take a look at Doug's site . . . and maybe ring him. Good call. Thanks!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    msg Posts: 10,532
    edited June 2021
    Glenn that was a joke! lol
    But he really could probably make you stuff.
