Low pass filter operation
Hello, I would like to use the subwoofer line out from a Dayton Hybrid Tube amp I recently purchased. This is a full frequency signal as the amp has no crossover built in. If I run the subwoofer out to my PSW 10 does the low pass filter still work in the subwoofer? Or does that low pass filter only work on speaker level inputs? Thanks in advance.
  • Gardenstater
    Gardenstater Posts: 4,803
    edited May 2021
    It looks like it will. If it had an LFE input the crossover would be bypassed but on the line input the crossover is in full effect. I'm assuming the amp you're talking about has a preamp out which is what you are using?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    It says RCA mono Subwoofer output so you should be good to go. They do not say anything about a low pass filter and the one in your subwoofer will be fully operational and adjustable on this input.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
