MagniFi Mini Will Not Reset Stored TV Remote Commands
forgetiii
Hi there! So I am running into an issue with my MagniFI Mini soundbar system where it will not reset my stored TV remote command settings for the volume up, volume down, and mute buttons on the remote. I have factory reset the Mini by holding the reset button on the back for 15 seconds, and it does reset/reboot the soundbar, removing settings for WiFi, but it still knows to take my TV remote commands for volume up, volume down, and mute.
Now, what I did to test something out was I started the learning process for the same TV remote, but I assigned numeric buttons 1, 2, and 3 as volume up, down, and mute. After finishing the learning process, the soundbar was able to control volume and mute with the 1, 2, and 3 buttons, as well as the volume up, down, and mute buttons. I then held the reset button on the back of the soundbar for 15 seconds, where it then reset/reboot. After rebooting, I verified that the soundbar did indeed remove the learned commands for numeric buttons 1, 2, and 3. BUT, the volume up, down, and mute buttons still controlled the Mini soundbar.
I am very confused as to how the soundbar is still storing the learned codes for the volume up, down, and mute buttons on my TV remote, and it is messing up how I am controlling the volume because it increases and decreases volume on both the TV and soundbar at the same time, which I do not want to happen. I only want my TV remote to control the volume on my TV and NOT the soundbar as well.
Any advice or help on what else I can try would be greatly appreciated!
