S55 Crossovers
jon2332
Good morning all.
Brand new to the board; thanks in advance for your patience.
I'm looking to upgrade the crossovers in my S55s but before I remove them and replace the parts, I'm curious if anyone has the schematic--or at the very least--the values of the inductors, resisters, and caps? In searching through the board, I've learned that getting a schematic is tough. I think I'll be able to reverse engineer it (hopefully), so at the very least a confirmation of which parts values I need would be great. Look forward to hearing from the community!
The schematic is not available. Pull a crossover, the values will be printed on the caps and resistors.
Thanks for such a quick reply. Excuse my ignorance, but will the inductors have ratings on them as well? I can see without removing any of the parts off the board at which levels the resistors and caps are rated but I don't see the inductors.
They will not.
OK. It's been a few months and I went forward with attempting to upgrade the crossover parts in my S55s. I would like to attach all the components I purchased point-to-point and disregard the board. The problem is I don't have the experience to feel confident in reverse engineering the schematic. I understand the basics but don't want to screw anything up. I searched an I can't find the diagram online.
Is anyone willing to help me with us? I like learning and would help any way I can. Definitely willing to pay for the time and effort.
Like most manufacturers Polk doesn't make public schematic drawings of current products. It might be easiest to simply remove a part and substitute the one you prefer. The problem that arrises is that often the replacement component is physically larger than the original. Kind of like fitting a size 13 foot in a size 9 shoe.
We MIGHT be able to trace the circuit if you post clear pics from the top and bottom of the crossover. The pics should be straight on. -
Thanks for responding. I’m very appreciative. I was able to find a volunteer to draw up a schematic. I soldered the components per the drawing and it worked like a charm. Boy, what a difference. The biggest change is the separation. Much cleaner sound.
Anyway, thanks again for taking the time to respond. In the case anyone is interested, this is the schematic I used.
