PSW650 driver connections
If I replace my bad plate amp with either an external amp or replacement plate amp, should the two 10" drivers be connected in parallel or series?
Answers
  • Thanks for the information. My unit powers up and can detect the presence of a signal but no little or no output. I removed the plate amp and did a visual inspection for anything obvious. I did find a transistor on the amp board with a couple insufficient wetting solder joints that I touched up. I wish I had your old post while I had it apart.
