"The Minimus" Project
13»
  • skrol
    skrol Posts: 3,497
    Very nice cuts. I see you switch to an oval cut out around the tweeter.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    VR3 Posts: 29,756
    edited September 2022
    Yes, same benefits but without harming the off axis performance
  • skrol
    skrol Posts: 3,497
    I pulled the grills off the my C series Minimus 7 and just siting the pads in place you can really hear how they tame some of the peaks in the highs and seem to have better focus. For grins I tried the other round pieces and they do kind of mess up the sound stage. The oval is the way to go.
    A note on the C series - The tweeter bezel is plastic and thicker than the A or B series that have the metal bezel. The thicker plastic bezel with the pad makes it hard to put the grills in place. I don't know how much market there is for these but may need to thin the pad for the C series.
    I am going to try the pads on my B series later but they definitely improve the sound.
    When my friend said that they had tried using felt pads around the tweeters on the Polk speakers with no improvement, I wonder if it was much thinner felt. These things are fairly thick and may do better on the vintage speakers.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,497
    I pulled the grills off the Minimus 7 C and just have the pads sitting in place. They really do tame some of the peaks in the highs. They are more focused and cleaner sounding. It is kind of surprising the difference with them on vs off. A definite improvement.
    One note for the Minimus 7 C. The tweeters have a thicker plastic bezel compared to the A and B with the thinner metal bezel. The thicker plastic makes it harder to fit the grills with the pads in place. I’ll try the pads on the B set later.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,497
    I tried them on the B version and the difference seems more subtle than the C version. The C normally is a little brighter than the B in spite of having basically the same tweeter. I was attributing it to possibly capacitor age. The XOs have the same value components but layout is a little different. Another difference is the B has fiberglass fill and the C has Daycron fill, not that it would impact the highs.
    40-2030B with pad
    40-2030B crossover
    40-2030C crossover
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,497
    The pads seem to make the most difference with grills on. I guess this makes sense since there would be reflections off the grill that are apparently absorbed by the anti-diffraction pads.
    Bottom line, they are keepers on the Minimus 7. The best configuration is with the pads in place and the grills off. Which probably also makes sense.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • plastic_avatar
    Jeezus. VR3... I thought I'd do a $50 mod to my 7's next year, but now...
    How much was the total in new parts fir the pair?
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    VR3 Posts: 29,756
    I can't recall exactly but it was around 200ish total in parts. I sold the pair for 280 shipped. Further proof properly done mods add value!
  • plastic_avatar
    "Further proof properly done mods add value!"
    Maybe I will Maximize my Minimus next year...
