Usher jumper bars or wires?
afterburnt
afterburnt Posts: 7,892
I am finally hooking up my MIT's. I have some WW bi-wires on them now so no need for jumpers of any kind. Do yooz think I should use the original jumper bars or make some wire jumpers?
    Clipdat Posts: 13,095
    Does MIT offer jumpers that match the cables?
    F1nut Posts: 51,786
    For now use the factory jumpers or make some out of whatever speaker cable you have laying around.
    I've made jumpers from the older MIT T2 bi-wire speaker cable in the past. It's a lot of work, which I don't care to do again. Last I looked MIT is selling pre-made jumpers, but they are not cheap.
  • afterburnt
    Just wondering if there's a sonic advantage. It was a no brainer on Polk Monitor II but the Usher bars are way more substantial and probably better material.
    F1nut Posts: 51,786
    I have to say that yes, there is a sonic benefit to using the same jumpers as ones speaker cables.
    VR3 Posts: 29,435
    edited February 2021
    Bi wiring smywiring, jumper spumpers
    IMO, no bar is good as wire, would you run a solid bar of copper from your amp to speakers?
    Just take the terminal cup off, run the top post wiring to the bottom post and leave the jumpers off 😁
  • afterburnt
    VR3 wrote: »
    @VR3 I respect your expertise but I don't understand you.
    VR3 Posts: 29,435
    Remove the terminal cup, take the wires going to the top post, disconnect them. Connect them to the bottom post.
    No jumpers needed anymore
  • afterburnt
    VR3 wrote: »
    Sounds like something I would do because I am sofa king!
