Where to people post home theater setups
In what forum do people post pictures/write ups of their home theater or audio setups? Any specific one on here?
Thx
    pitdogg2 Posts: 27,527
    Welcome aboard.
    Try the search feature.
  • Thanks for the suggestion but I did try a few searches on "Home Theater" , etc... I am just not sure if there is a dedicated forum for displaying and showing off your set up. If I were to post my setup, what category would be the best forum to post it in? I feel like it should be obvious and I am missing something.
    VR3 Posts: 29,622
    Speaker section
  • PSOVLSK
    PSOVLSK Posts: 5,410
    I’m being too lazy to search myself, but try “system showcase”. Not sure if that thread is still around or not.
    VR3 Posts: 29,622
    System showcase died with the change over many years ago unfortunately
  • BlueFox
    BlueFox Posts: 15,250
    I suppose it depends on what you want to discuss. If the electronics then the ‘Electronics’ section would appear relevant. If the speakers then, as mentioned earlier, the ‘Speakers’ section. If just a general discussion then the ‘Clubhouse’ might be relevant.
  • PSOVLSK
    VR3 wrote: »
    That’s right. Didn’t someone start another similar thread? I could be mistaken; but even if I’m correct, I don’t know how to find the thread I’m thinking of.
  • vmaxer
    vmaxer Posts: 5,121
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Thanks all. Appreciate the replies. It seems pretty odd to not have a system showcase forum category like the one that was discontinued. It would be free advertising and marketing for Polk if people had a dedicated forum category to display their home theater and home audio setups with Polk speakers. You could easily browse through different posts to see how everyone set up their systems and overcome room limitations and layout options all in one spot. They really missed the boat on this opportunity. I wanted to post my budget setup but couldn't figure out where after searching the forum. There should be an entire category on this.
  • We'll, I went ahead and posted my home theater build in the speaker section. No idea if that is the proper place but again thanks all for your replies.
