Tweeters
I’m trying to remove my tweeters from my monitor 10a speaker, but the wires are soldered to the tweeter how would I remove it?
Best Answer
  • Gardenstater
    Gardenstater Posts: 4,859
    edited February 2021 Answer ✓
    I didn't risk it with mine. I cut the wire to a 1" length and crimped and backflow soldered on some 7/64" (0.109") male fastons. Actually, I made them myself from 4N copper and copper crimp sleeves.
    If you attempt de-soldering, you'd better have some good clip on aluminum heatsink clamps on the terminals and work quickly.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
Answers
    F1nut Posts: 52,203
    Desolder the connection.
  • polklover656
    Will the heat damage the tweeter? That may be a problem, I have not experience with soldering...
    F1nut Posts: 52,203
    If you don't know what doing, don't do it.
  • polklover656
    Amazing idea gardenstater, Smart outside the box :) that’s what I’ll do
