Phono Cartridge Recommendation
xsmi
So I have a Pro-Ject RPM-10 coming in that doesn't have a cartridge (an offer I simply couldn't refuse). Normally here in the states, if you do the package deal, they throw in a Sumiko Blackbird MC cartridge. However, before I spend $1000. on a cartridge, I want know if anyone has any other suggestions in that $1000 price range?
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
The Hanas are getting a lot of attention in the marketplace. I would like to try one on my Denon table.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
I don't see a lot of people gravitating towards the Sumiko carts unless they are bundled with the TT. I would speak with a local dealer who may be in a position to demo a couple carts. Hana does get high praise and would be on my list, but I would also want to consider less common carts like Soundsmith and Van Dan Hul.Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
@xsmi Are you going to get another phonostage as well...or do you already have another one besides your Pro-ject Phono Box MM?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Easy choice and there's one fs here in the Polk marketplace; Clearaudio Stradivari.
I got an email from Osage Audio just yesterday including a special on the Hana ML, regularly $1200. Now $1000 until the 12th. Not sure if the high-output version is included. If that was my budget, I’d consider it along with models from Soundsmith, Clearaudio and others.
I have a Schiit right now, but it’s coming with a Moon LP3. This little Schiit has been amazing though, especially for the money.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
motorstereo wrote: »Easy choice and there's one fs here in the Polk marketplace; Clearaudio Stradivari.
I forgot about this. If John still has it then its a no brainer.
https://forum.polkaudio.com/discussion/193056/clearaudio-stradivari-wonderful-mc-cartridge-1000-00-obo#latest
2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
SpongeBob bought that."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I thought so.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Sorry I didn't see where he'd bought it. But I'm glad he did as I was thinking about it as a back up for my Strad
Also, reading today, this machine normally comes with a Sumiko Sterling which is $1800. that's almost how much I gave for the less than one year old table.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Yeah, they did the deal over in this thread: https://forum.polkaudio.com/discussion/comment/2628472#Comment_2628472motorstereo wrote: »Sorry I didn't see where he'd bought it. But I'm glad he did as I was thinking about it as a back up for my Strad
So, I've talked to several retailers who said that the Sterling/RPM-10 combination is magical. However, with the two phono pre's that I will have, they recommend not spending almost two grand on a cartridge unless I am also open to spending a grand to get a pre to get the most out of that cartridge. Two of the three recommended the Songbird the other, the Hana M.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
I would like to try a Hana someday. I'd probably go for the SL."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Heard good things about this cartridge: https://www.lpgear.com/product/atc01.html
So, I ended up buying local and getting the Sumiko Blackbird. And because its going to take up to 10 days I was given a Grado Green to use in the meantime.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Well you should hear a marked difference between those two! Congrats on the Blackbird, and keep us posted
I have the AT OC9ml the original and simply love it to death.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The original and MkII are lower compliance, so need a heavier arm. The MkIII has higher compliance, although does run at a slightly higher VTF...go figure. The original version I have is tired and probably needs a retip at this point; I bought it cheap with an unknown number of hours on it. My MkIII still sings like a bird!soundfreak1 wrote: »Heard good things about this cartridge: https://www.lpgear.com/product/atc01.html
I have the AT OC9ml the original and simply love it to death."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
If I'm not mistaken there is a difference in the stylus and cantilever type between the original and following editions as well. bought mine new so I still have lots of life.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Indeed:soundfreak1 wrote: »If I'm not mistaken there is a difference in the stylus and cantilever type between the original and following editions as well. bought mine new so I still have lots of life.
Image borrowed from here: https://www.vinylengine.com/turntable_forum/viewtopic.php?f=19&t=104718 but you have to look through the whole thread as the 'grid' was updated along the way. Many iterations of the OC9 over the years, but there's no mistaking that body-style."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
This is the one I have.
Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Someone in that thread on VE has one like that as well. The 'ML' sticker indicates how it was a transitional model between the original OC9 and the OC9ML/II. Instead of printing new boxes, they just put the sticker on to differentiate between the original OC9 with elliptical tip, and this ML version with micro-line. Rare and cool!"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
The OC9ML/II was my favorite cartridge back when I had a phono stage that could do .4mV MC. Since I built my Pass DIY Pearl phono stage, I've had to stick to MM or high output MC. Still trying to find the perfect one that doesn't break the bank. I've had a vintage AT15SA for many years, replaced the stylus with a NOS original at one point about 12 years ago. It just doesn't pull the music out of the groove like that ML tip does.See profile for rigs. Nothing else here.
I'm partial to the ML, loved the ML on the old Shure V-15iii I had. But this oC9ml just floats my boat.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
@xsmi
Congrats on the Blackbird and the RPM10
Wow, I’m sure that’s a fantastic analog set up you got thereMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
@xsmi
Thanks Joey. I'm happy with it, I just need to get the SRS's dialed in. Right now, the sound stage is skewed to the right.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
