Retrieve item inside Polk S10 speaker
efung
While trying to mount the Polk S10 satellite speaker to a Perlesmith Floor Speaker stand, I accidentally dropped the keyhole hanging screw inside the speaker.
It's not rattling around inside, and must be stuck to a magnet.
I removed the back grill (where the keyhole mount is) with a hex key, and took out the piece where the binding posts are. But I can't see the loose screw, and there isn't enough room to fish around in there.
On the front, I removed the four hex screws, but I can't figure out how to remove the shiny black faceplate. It might be glued on? Anyone ever tried opening up the S10 before?
I found a YouTube video where someone took apart a Polk S15. But they just pry off the faceplate and loosen the glued points.
Update: I got my 6-yr old daughter to reach in from the partial opening where the binding posts are, and she was able to feel around the magnet and retrieve the screw. My hero.
Crisis and sadness averted! -
That was the best use of child labor I've ever heard!I disabled signatures.
