Monster Cable Terminators
Pablo
Pablo Posts: 723
I have a pair of good monster cable (not sure which model, but they are at least a 12g and were the best speaker cables in the store when it closed out everything) with a pin type terminator. It really doesn't fit the speakers to well. Should I cut them off and replace them, or is having the factory conection at the end better?
Paul
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • Willow
    Willow Posts: 11,371
    edited June 2004
    have you inserted them under the binding post screw ??
  • mantis
    mantis Posts: 17,694
    edited June 2004
    Cut them and buy the Monster lock system.Then you can change the tips at will.They use a screw on end which is nice,the base gets crimped on.
    Cut away and reterminate.If your unconfortable,stop by your local Tweeter and get some help there.
    Dan
    Dan
  • Pablo
    Pablo Posts: 723
    edited June 2004
    Willow, I have them inserted through the hole under the binding post screw, but the ends are so bulky (not the pin part), that it just doesn't look like it gets a good conection (if you move the speaker around, they will fall out).
    I might check out that Monster Lock thing and replace both ends.
    thanks for the advise.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    Csi-40 Center
    PSW350 Sub
    Denon DVD-2910
  • Willow
    edited June 2004
    ahh ok then like he said...go buy some better ends
