Mounting glass shelves
So being the cheap bastages that we are, we bought this cabinet at an outlet for 63% off. Some imperfections, but main problem is that it was missing the glass shelves. Getting replacement shelves made was easy, the hard part for me is figuring out how to mount them. Any ideas? Thx fellas!
Game Room 5.1.4:
Bedroom 2.1
  • maxward
    maxward Posts: 1,708
    Try to find some shelf pins/pegs that fit that size of opening. The head should fit into the circular part and slide down. Also could have soft plastic sleeves on them to protect the glass. If Home Depot or Lowes don’t have them, there are others out there, like Rockler.
    EndersShadow Posts: 17,713
    rooftop59 wrote: »
    So being the cheap bastages that we are.....
    I knew there was a reason I liked you :wink:
    F1nut Posts: 51,870
    The doors don't line up. Try leveling the cabinet to correct that.
    I've seen thousands of various cabinets, bookcases, shelving units, etc, but nothing with that keyhole type shelf support. Let me look around.
    F1nut Posts: 51,870
    edited January 2021
    Ok, there doesn't seem to be anything purpose made, so use machine screws or bolts. The head size should fit through the larger hole and have enough of a flat shoulder to prevent it from pulling out when positioned in the lower opening. Use clear plastic tubing to cover the part of the screw or bolt that will actually support the shelf.
  • maxward
    Good idea there, and cheap.
  • afterburnt
    afterburnt Posts: 7,892
    oic, I was gonna tell you that you should probably get a girlfriend.
  • rooftop59
    rooftop59 Posts: 8,120
    edited January 2021
    Thx Jesse! That seemed to work. The wife will be happy with it. Here is what I went with:
    As for the doors, the cabinet is level. They’re not budging. That was the other main imperfection. My wife is very picky but also very cheap, ya never know which one will win out 😂
    Game Room 5.1.4:
    Bedroom 2.1
    Clipdat Posts: 13,098
    Good job! What are you going to put inside it?
  • rooftop59
    Clipdat wrote: »
    Thx! She will put whatever she wants in it 😂
    Game Room 5.1.4:
    Bedroom 2.1
  • tonyp063
    tonyp063 Posts: 1,135
    edited January 2021
    "Yes honey, I did buy that <audio_thing>.
    Got a better discount on it than we got on your shelf cabinet" !!
    Only once though.
    Choose wisely.
    F1nut Posts: 51,870
    edited January 2021
    The nut was a good idea.
    As for the door, I'd maybe try shims on the hinge pins and/or whacking a few of the bottom hinges inward, which will raise the left side of the door upwards. Take the glass out first if you do any whacking.
    Toolfan66 Posts: 18,117
    edited January 2021
    I wonder if you can find some black rubber plugs that you can slide over the threaded bolt to sit the glass on??
    Or some small black tubing/hose??
    pitdogg2 Posts: 27,143
    I was thinking the same thing Mr. Toolfan
  • rooftop59
    Toolfan66 wrote: »
    Not sure what you mean Larry? Do you have a link or pic? Thanks! Paul
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    rooftop59 wrote: »
    $1500 piece for $450. It was hard to pass up! the shelves only cost $150.
    Game Room 5.1.4:
    Bedroom 2.1
  • Hermitism
    Hermitism Posts: 4,329
    rooftop59 wrote: »
    Toolfan66 wrote: »
    I think he means something like this...
    https://www.amazon.com/SBDs-Pack-10-Flexible-Protector/dp/B07BVCBS71?ref_=ws_cp_69a2500c76b33b2566fc_p_2_t_p
    ^^^that
    Or just simply like black tubing from the auto store. Fit the bolt diameter little 1/4"-1/2" in length. Just to have bolt on rubber instead of metal glass contact.
    F1nut Posts: 51,870
    Looks like there is heatshrink or the like on the threads already.
    Guess you're correct. My first look I just thought it was a Black bolt. my second look I now can see the silver underneath whatever that is black on there so I am going to say you're probably correct it shrink tubing.
    F1nut Posts: 51,870
    They don't call me eagle eyes for nothing. B)
    I know what they really call you....
    B)B)
    Yep, I see it now as well, I was thinking they were black zinc.. Good eye.. I was thinking what hermitism posted..
  • rooftop59
    Yep that’s it! I think it’s good now, but I’ll know for sure once something gets put in there!
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    The nut was a good idea. Take the glass out first if you do any whacking.
    If you are gonna be whacking who is gonna fix the door? If you take out the glass post a video.
