SDA 2B Image Issue
I have an issue where my center image has drifted about a foot to the right. I have swapped out everything. I made a new interconnect cable to see if it was my Dreadnaught/connections and I still had the same issue. I disconnected the interconnect and the center image is dead center. So I think my SDA circuit in one of the crossovers is bad. Has anyone ever had an issue like this? I am about to pull the crossovers again. Any suggestions on what I should look for?
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    pitdogg2 Posts: 27,209
    Have they ever been recapped Scott?
    I'm assuming as long as you've been here the answer is yes.
  • Yes. But I did it in 2007. I am thinking about picking up the replacement boards and building new crossovers.
    audioluvr Posts: 5,982
    I had an issue similar to this and attributed it to room positioning of my speakers but then I had my amps rebuilt and it went away. Something was out of spec so I think you're onto something about the dimensional array being out of spec somewhere.
    gimpod boards? if not then yes get some of those boards from Dave @westmassguy
