Just picked up 2.3's...Basket case project! Need advice
Hi there and thanks in advance! This is my first post, but I have been reading this site off and on for years, made a profile to tell the tale, and get advice.
So I saw the CL ad locally for 2.3's (been waiting for some SDA's to come up). I love a project and boy do I have one here. I was able to negotiate the price to what I thought was a good deal. He knew they were a project and we worked out a fair deal (<$500). I figured the tweeters would be most of that anyway.
These are not in the best shape but there is a silver lining (I hope). Plus, it did come with the blade/pin cable.
According to the owner, Eight MW have been replaced with Polk versions about 5 years ago along with the tweeters. The owner "redid" the crossovers at that point by replacing the OEM caps with Dayton's. I have not checked the values, but I can assume they are correct. The worse part as you can see in the pics is that he did not notch the surrounds prior to **** in the MW's. Most of the issues are repairable with some surround adhesive. The grills and the side panels have been molested by a Cat that has since passed (hopefully because of this).
I have ordered adhesive, hurricane nuts, and screws. I am sourcing the correct fabric for the grills and the side panels. This forum has provided me with a wealth of knowledge on mods and the like.
kickngas
Wilmington, NC
    Tony M Posts: 12,028
    I'm glad you got them. ;) I almost went to look at them yesterday if they were still for sale! I went and bought a camera instead.
    Looks like you have the issues fixed so far.
    Let us know how they sound.
  • Gardenstater
    "According to the owner, Eight MW have been replaced with Polk versions about 5 years ago along with the tweeters.
    Well I kind of question whether those are really drivers of Polk manufacture. In my admittedly limited experience I have never seen cones or surrounds or labels or basket frames that look quite like those. I think you will have a hard time making a satisfactory repair on those surrounds with glue. I have never seen Polk OEM surrounds that didn't have the small rectangular shaped notch out for the screw heads.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    gudnoyez Posts: 8,223
    Yep something about those MW's dont look right but for the price you got them for seems reasonable.
  • kickngas
    Tony M wrote: »
    When I get them finished, you can come to take glamour shots of them! ;) Yeah, a nice guy, and fellow vintage audio tinkerer. If I can't get satisfactory results from my repairs, I will gradually replace them with OEM drivers as they pop up online.
    As for the MW's, they do have Polk labels and look legit. I have no reason to doubt the original owner, but who knows. Maybe someone can chime in on their authenticity.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Those are the replacement drivers that Polk offered a few years ago. They did not have the notch for the cap screws and consequently many suffered the same demise as these pictured. They will have to be replaced, but may not be available from Polk any longer?
  • Emlyn
    Emlyn Posts: 4,920
    I remember there being a batch of midwoofers from back around that time that did not have the rubber surrounds properly trimmed. Manufacturing defect from a supplier.
    On the bright side, those tweeters would have cost $300 anyway.
    But now I'm curious about what the censored word was in front of "in the MW's."
  • kickngas
    Simply a typo. Insert any expletive there! (Should have been **** in the MW's). I didn't notice it until you pointed it out...had to look back at the post.
    F1nut Posts: 52,406
    The censored word is s c r e w i n g.
    The crossover work is disgraceful. You'll never salvage the surrounds.
  • Gardenstater
    Gardenstater Posts: 4,985
    edited December 2020
    s*c*r*e*w*e*d <<<< what I read it as lol.
    Hopefully you can fix the surrounds (multiple thin layers of Ayleens Tacky Glue perhaps?). Some of my notches didn't quite clear the screw heads on my MW's and I used a piece of brass tubing that I sharpened with a tapered reamer, that is larger than the screw heads to cut away the excess rubber. I felt more comfortable using that than an xacto knife, one slip of which could be disastrous!
    It's generally considered bad practice to use multiple capacitors to make up a value unless there is no other option, for the simple reason that it takes up more pcb real estate, and then they should be as equal in value as possible. Also leads should be kept short and there should be some sort of cushion between the capacitor and the board, with a cable tie or the like. Polk relied heavily upon hot melt glue.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,406
    It's not considered bad practice to use multiple caps to make up the value required, but they should as close in value as possible. What is bad practice is to use a much smaller value with a large value as the smaller value tends to act as a bypass.
  • kickngas
    Thanks for the tip George. Yeah, F1, I took one look at the X-Overs and had to look away! Gotta start my parts list for sure. Baby steps. Is there a member here who has a stash of MW's squirreled away? Otherwise, I will be patient in my search and cross my fingers that I can salvage a few of these.
  • motorstereo
    motorstereo Posts: 2,428
    Great advice for sure; I remember when I had my 2.3s crossovers rebuilt by a fellow that should've known what he was doing. He used smaller bypass caps to add up to what was needed for whatever reason I'll never know. His reasoning at the time was JBL does it so it must be ok.
  • BlueBirdMusic
    kickngas, Good luck on your journey. You are correct about your description of the previous owner.
    "vintage audio tinkerer"
    I would add to that:
    "vintage audio tinkerer without any touch"
    Harry / Marietta GA
  • kickngas
    Haha, yeah the attention to detail was just not there. He had good intentions.
  • VSAT88
    VSAT88 Posts: 1,390
    Crossovers look like some crap I would build. LOL !
  • kickngas
    VSAT88 wrote: »
    One step at a time! Taking care of the easy items first, mostly aesthetics ie. Grill cloth, re-cover the side panels. Already have hurricane nuts, scres and washers on the way. Searching for a few replacement drivers, then get them up and running while I collect crossover components. I at least want to he able to compare old vs. New.
  • skrol
    skrol Posts: 3,499
    Perhaps some E6000 glue on the surrounds. It can be applied very thin and holds very well. Just let dry and out gas well before reinstalling the drivers.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,499
    "..let dry and out gas well.."
    Good advice when sharing a sleeping bag.
    Beans over the camp fire eh? I have visions of Blazing Saddles.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • halo71
    halo71 Posts: 4,645
    Wow! My questions would be...1.Why were all the midwoofers replaced? And....2. After putting the first screw in and seeing what it did to the surround. Why would he have kept going. And basically ruining the remaining drivers?
    --Gary--
  • kickngas
    I did not ask why the drivers were replaced. I also thought the same thing about the persistence of damaging the remaining drivers. Something I would expect from a middle school kid, but not this guy...he showed me several projects he was/had worked on and all was good. Possibly bought them as a project and lost interest maybe? Who knows.
  • kickngas
    Interconnect cable question: if the blade is used for support only, why is it wired over to the negative terminal? I checked my cable and have continuity on the pin, but nothing on the blade.5zloa9zubvbg.jpg
  • Unknown
  • kickngas
    kickngas Posts: 35
    Thank you for your reply Pittdog, I just didn't want to sink more money into this if not needed. I will probably make a new one using a nNeutrik cable in the future. Now, on to crossover part search for that project within a project!
    I just found another post about it, and it has the schematic and an explanation from you as well. 3jl3z3tlel5z.png
  • kickngas
    UPDATE:
    I finally got a little bit of time to work on these puppies. I have:
    Made temporary repairs to the damaged rubber surrounds (will replace drivers as I find them)
    Installed Hurricane Nuts
    Caulked inside perimeter of enclosures
    Applied Powergrab to magnets/frames
    Applied plumbers putty on the back of the all frames
    Used Armacell for gaskets
    Cleaned up the crossovers a bit (will go full Gimpod replacements soon)
    Refinished the wood top and bottom caps.
    Bought grille cloth (next project) side panels will be more of an effort
    Need to buy spikes too.
    Results: I only have one up and running, and it sounds great until I turn it up. One of my MW6511's are about toasted. Voice coil is obviously coming apart (thank you previous owner). These things are as hard as hens teeth to find.
    BEGGING ANYONE THAT HAS 6511 or 6510's they are willing to sell. I have reached out to folks on eBay, but that is hit or miss. I would much rather purchase from someone on these boards.
    So, please PM or post here if you can help out 😁.
    Is there a database of which Polks use the 6510 or 6511's? That would help me expand my search for ones being parted out.
    F1nut Posts: 52,406
    Plumber 's putty has no business on driver baskets. Please use a product such as Dynamat Xtreme.
    F1nut Posts: 52,406
    MW6511
    CRS+
    2B
    1C
    3.1TL
    1.2
    1.2TL
    MW6510
    CRS+
    2A
    1C
    SRS2
    2.3TL
  • kickngas
    Thanks F1 for the reference list. I can't find where the putty is a detriment to the frame. I kinda liked the application process anyway! Cathartic.
    F1nut Posts: 52,406
    It's a matter of purpose. Dynamat Xtreme is a very purpose designed sound dampening material. Plumber's putty is not even close.
