Tri-amp SDA-SRS
Dsaniti
Dsaniti Posts: 1
edited November 2020 in Vintage Speakers
I have tri-amped by SDA-SRS 2.3 speakers for year. That perform great.
I use 2 mono blocks for L/R low frequencies and a stereo for the highs. Jumpers on the speaker inputs removed. Need to connect an extra negative pending post on each of the mono blocks together to establish a common ground as required by the SDA speakers.
Please don’t comment on the room setup. This sucks and will change. I had to keep these in a box for the past 10 years due to travel. I purchased them new back in 1991. Working on constructing a new 20x25 foot listening room to put them as the final home.
  • engie490
    engie490 Posts: 447
    Dsaniti wrote: »
    Looks like a nice setup!
    Technically, I would call it biamping. You have a stereo amp on the highs and monos on the bass.
    But, you're doing it correctly. Assuming those are 565 monos, the 585 is just a stereo version of the 565, so you essentially have the same amp on the top and bottom with identical gain.
    Have you tried either the 565s or the 585 by themselves?
    On a related note, any capacitor problems in the amps?
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    F1nut Posts: 52,299
    engie490 is correct, you are passive bi-amping. The reality is to tri-amp you would need 3 separate binding post connections, one for the high, one for the mid and one for the low, but wait there is no bass driver, so you cannot tri-amp.
  • Schurkey
    Schurkey Posts: 2,125
    Yup...looks like fun.
    By all means, verify the capacitors in those amplifiers. 565s and 585s were made during the years of Capacitor Plague; if you happened to get amps with the faulty caps, there can be significant damage done to the circuit boards. And it was fairly common with those Adcoms.
  • VSAT88
    VSAT88 Posts: 1,379
    edited December 2020
    Agree ^. Main/driver boards..
