Quick-Disconnect Tabs
Hi guys,
Do any of you know where I can find some of these?
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Gardenstater
    Gardenstater Posts: 4,804
    edited November 2020
    It's a male faston or male spade quick disconnect. They have crimp on and pc board mount varieties. They are not as readily found in retail stores as the female ones but they are out there. You may have better luck on amazon and ebay.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • xsmi
    xsmi Posts: 1,804
    I've tried those two as well as parts express.
  • What size exactly, and is that a riveted on tab for a speaker terminal? That might be pretty hard to find and might be something that the speaker mfg's have made specially for themselves.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Yes it is riveted. They are 1/8".
    F1nut Posts: 52,032
    xsmi wrote: »
    Hi guys,
    That's a riveted faston. Have fun, https://www.te.com/global-en/plp/faston/ZnaA.html
    Can you not figure out a way to mushroom the rivet head to reinstall it?
  • xsmi
    xsmi Posts: 1,804
    No I just want all new ones.
  • Gardenstater
    I found this one at the link F1 put up. You could use a 3/16" pop rivet and use a little solder as well. https://www.te.com/global-en/product-63038-2.html
    Edit - scratch the above. It's 1/4" and you need 1/8")?
    I don't see anything but .250 at TE connectivity:
    https://www.te.com/global-en/plp/faston/ZnaA.html?q=&n=129392 608518&d=636113&type=products&samples=N&inStoreWithoutPL=false&instock=N
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Yeah. That's what I'm finding too.
  • xsmi
    xsmi Posts: 1,804
    So I think I found some. They are .187. Do you think I need the rivets, or will there not be a contact with the board? These are for my SDA SRS Boards.
    https://www.mouser.com/ProductDetail/571-616641
  • If you have a way to hold them in place tightly while you solder them, I don't see why you would have to have a rivet. Are they at the edge of the board where you could clamp them with a small C-clamp or alligator clip? You need to not suck all the heat out though. Maybe a wooden clothespin?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Yes. They’re on the edge. The ones I took of, by accident are circled in Yellow. I want to ad some at the red circles.
  • OK so the copper is on the bottom side. Well if it was me I'd want to use a rivet. Are you sure you can't re-use the existing ones and use a nice solid Center Punch with a hammer on the hollow side to splay it out and a solid metal anvil on the other? McMaster Carr probably has hollow rivets.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Ok. Probably.
    pitdogg2 Posts: 27,376
    Don't think I'd hit too hard on that board re-mushroom anything.
  • Gardenstater
    Yes it would require a delicate touch, and the head of the rivet has to be supported by something solid like an anvil and something has to support the remainder of the PCB. Kind of tricky. You could also use an aluminum pop rivet and punch out the mandrel (or just leave it) and then solder.
    They make tools for hollow rivets but they are crazy expensive, like over $50 at McMaster Carr:
    https://www.mcmaster.com/hollow-rivets
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Yeah. Ok. My question was for the ones that I want to add that don’t come with rivets. With solder can they make contact with the leads on the board with out a rivet.
  • The rivet would be there to make a strong physical connection without relying upon solder for that. The solder would ensure a good electrical connection that doesn't rely totally upon the contact force between the tab and the copper traces caused by the smashed rivet. I would do both. Would solder alone be strong enough? Maybe. Would the rivet alone be enough for a decent electrical connection? Maybe.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    Gotcha. I was wanted to add these because eventually I want to rewire the inside and I thought I'd want to be able to just disconnect everything and not have to use solder. But, Oh well.
  • Sorry, I was talking about the ones you took off by accident. Did you already put them back on? I assumed that the picture was from before you took them off. I don't know about the practicality of putting spades in for the other connections. They might be too close together. It would help if you showed the other side of the board, where the copper traces are.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,804
    I haven’t yet. Getting ready for the holidays so everything is put away. I’ll put them back on over the weekend.
