Anyone ever "Dry Brine" a turkey?
If so, how did it turn out?
    Viking64 Posts: 7,631
    afterburnt wrote: »
    Dry.
    And briny.
  • afterburnt
    afterburnt Posts: 7,892
    Viking64 wrote: »
    afterburnt wrote: »
    Dry.
    And briny.
    So how do you prepare your bird now?
  • NotaSuv
    NotaSuv Posts: 3,871
    dry brine and into the q, indirect heat...wood chips at the end optional but does add a nice taste.....
  • Gardenstater
    Gardenstater Posts: 4,804
    edited November 2020
    I have always cooked mine upside down in a rack. You start out at a high temperature and gradually lower it in a couple of steps and then it is finished at around 225 for quite a while until it is done. You stuff it with aromatics like garlic, celery tops, carrots, onions, thyme, parsley and lemon juice and salt first and rub it all over outside with olive oil and salt and pepper. Makes a great gravy. The breast never is dry this way. If you're a crispy skin person not the greatest way. If you want crispier breast skin you can turn it over and put it under the broiler for a few minutes to finish. https://www.simplyrecipes.com/recipes/moms_roast_turkey/
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    afterburnt wrote: »
    Viking64 wrote: »
    afterburnt wrote: »
    Dry.
    And briny.
    I have never cooked a turkey in my life.
    Cows > Pigs > Birds
  • cmy330go
    cmy330go Posts: 2,341
    Due to turkey being on the drier side already, I think you'll have better luck with a regular brine. I think you'll just lose too much valuable moisture with a dry brine.
    https://www.youtube.com/watch?v=2zWHOEkBLAg
    I'd recommend doing something close to what is in this video. If you don't have the fridge space, just use an appropriate size cooler, and add ice to the brine.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • afterburnt
    cmy330go wrote: »
    I am cooking it in a smoker and so far from what I gather dry brining will keep the skin from being rubbery. I hope I don't screw it up but I am cooking a shoulder roast, scallops, salmon and, lobster tails so there should be something edible when I am done.
  • cmy330go
    Wow! That sounds good, and also like a lot to shuffle. Hope all goes well!
    HT
    2 CH
  • afterburnt
    cmy330go wrote: »
    Thanks, that stuff is easy, the work is in the prep. I am also doing four sides, biscuits, and two desserts. :#
  • rooftop59
    rooftop59 Posts: 8,120
    Bruce this is the recipe I have followed for smoking a turkey the last several years. It’s one of the best turkeys I’ve ever had.
    https://amazingribs.com/tested-recipes/turkey-recipes/bbq-and-grilled-turkey-recipe
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    Thanks Ivan I will check it out.
