gear pics
superbrett
superbrett Posts: 106
Finally lugged the SVS into the house, been in the garage since Friday...
Holy crap! Where did all the room go?
HAvn't had much time to play yet.
Does it matter WHICH port/s I block? (PB2-ISD)
"Looks good from far, but far from good!"
Post edited by superbrett on
  • superbrett
    edited June 2004
    SVS
  • Willow
    Willow Posts: 11,308
    edited June 2004
    what took you so long to bring it in !!!! what are you using for rears ?? rti4's ??? is one side of your couch closer than the other to the side wall ??? the reason I ask is thats my case
  • superbrett
    edited June 2004
    Long weekend, we were at the lake most of it, just got around to doing it this morning...anyway, my rear surrounds are Fxi3's.
    I'm not sure what you mean about the coutch being closer to one wall.
    On the left side, there is a door opening, the other is the SVS, and It's centered between the two, if that helps!
  • Willow
    edited June 2004
    you understood....ahh the fxi3..... cool set up
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    What receiver you have? Are those RTi12 or RTi8 or RTi10. I can see HK PA2000 2-ch AMP.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • superbrett
    edited June 2004
    I have the HK AVR 430, and RTi8's.
  • danger boy
    danger boy Posts: 15,722
    edited June 2004
    LQQKIN' good there superbrett. I bet that SVS kicks some butt. ;)
    suggestion. you may want to raise your surrounds farther up on the wall. When i first got my surrouds.. i had them at ear level too. the tweeter were to much to handle. but raising them up another couple feet helped with that.
    nice set up btw.
    PolkFest 2012, who's going>?
  • superbrett
    edited June 2004
    Thanks for the suggestions...actually, I'm drawing up some speaker stands as we speak, I DO want them alittle higher, but I really don't like the looks of them ON the wall. The highest stand I can find is 36", but I kinda like to build things anyway, so I'm going to shoot ofr 42" or so...I'll post some pics when I get em done.
    I appricaite all the compliments, this is my first dive into HT, it's really cool to have a forum and support like this!
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    Agree with dangerboy, place your surrounds higher, you'll notice greater sense of surround effects. In actual theater, surround speakers are placed higher as well.
    I use FX1000 one of the largest surround dipole/bipole speakers Polk ever made. Too bad they don't make them anymore. I placed them high as much as possible. They are as good as my fronts. Not too many people own them, the reason is they are big and meant for larger rooms.
    I love them.
    NAD C272 (2-ch Amp)
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    Your HK 430 I think it has enough power to drive all the speakers then why you got HK PA2000. Did you bi-amped your fronts.
    NAD C272 (2-ch Amp)
  • superbrett
    edited June 2004
    Indeed I did. I'm kicking around the idea of putting the PA 2000 on rear surround duty, and getting three of the Outlaw M-200 Monoblocks to power my fronts and center.
    Not totally sold on it yet though.
  • mantis
    mantis Posts: 17,611
    edited June 2004
    I suggest you hang those rears at 72 inches from the floor.Run the wire inside the wall for a clean look.If no access from the basement is there,then go into the attic to run.If no access anywhere,use cable plates,take the barrel out of the place,run the wire up the wall to the speaker location and install the plate(while you run the wire up,be sure to wire it threw the front to back).
    system looks good other then the rear placement.Do you run the sub out of phase????I would
    Dan
    Dan
  • Mike682
    Mike682 Posts: 2,074
    edited June 2004
    Superbrett,
    Do you find that the h/k gets hot?
    From the pic it looks like you don't have much room for ventilation for the h/k. I have the 225 and I need at least 6-8" clearance from the top of the receiver to the bottom of my shelf or else it gets very hot. The extra clearance did the trick and now it runs pretty cool....
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • superbrett
    edited June 2004
    I only have about 1 1/2" of clearance above the HK, I really thought it was going to be a problem, but It just didn't look right anywhere else.....(according to the Girlfriend that is!)
    I have an old computer that I'd had since high school, I swiped the little exhaust fan out of it, and rigged it as an exhaust fan with a small hole in the back of my ent. center.
    It's really quiet, I don't even know it's there. I listen at decent volumes in two channel, and have yet had to have the hk shutdown....you're right though, thing does get pretty warm.
    Cross my fingers!
  • johnny_utah
    johnny_utah Posts: 117
    edited June 2004
    Dan
    I have seen this switch on the back of my sub. What does it do?
  • Willow
    edited June 2004
    what I have heard is if the sub is in the front of the room it should be at 0 if its at the back or you have two subs on top of each other it should be 180...but that doesn't mean you can set it to what you want if you like it at 0 when the sub is in the back of the room then leave it ...but I do suggest you try playing with the phase
  • mrmusicman
    mrmusicman Posts: 303
    edited June 2004
    Is it ok to have the tv directly on top of the center?kinda heavy isn't it?
    Outlaw 990 Processor
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    Kenwood Excelon KDC-X891
    JL Audio 300/V2
    Polk Audio SR 6500 - Fronts
    Polk Audio DB651 - Rear
    2 -10" Treo Subs
    Interfire IB 2600C sub amp
    Sirius Sat radio
    Ipod connection
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2004
    i dont think the tv is directly ontop of the center....look again, closer
    running the sub at 180 degrees means that the driver is pulled in to produce bass instead of 0 degrees which pushes the driver out to produce bass ( atleast im pretty sure that's whats going on)
    VR3 Posts: 29,627
    edited June 2004
    I have found, in my room (even with the sub in the front of the room) - 180 degree phase sounds best. Absolutely slams. lol
  • michael_w
    michael_w Posts: 2,813
    edited June 2004
    For the placement of your svs ... it looks good where it is but doens't it seperate from the sound too much since its right beside you? My dad has his sub in practiacally the same setup as you and my subs are up at the front.... mine blend in with my fronts very well but as for my dads it sounds almost artifical because its so obvious that theres a sub 3 feet to your right (left in ur case but anyways). Although it looks like other placements might not be up to the girlfriend approval standard :p . Just an idea.
  • superbrett
    edited June 2004
    Musicman...the center isn't supporting the TV. If you look closely, I made two little "risers" on each side of the speaker, they are just higher than the center channel.
    It fools alot of people...kinda fun!
    A far as the sub being out of phase, I run it at normal.
    I don't have a SPL, but to my ear, it sounds best when in normal.....who knows.
    The placement issue.....My receiver has a delay feature which lets you adjust how far away each speaker is...(In feet). I played around a little and found if I delayed the sub by a few feet, it all blended together nicely...Again, I don;t have an SPL....just my ears...no complaints so far!
    Thanks for all the compliments guys!
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2004
    You should add your nice setup to the System Showcase.
    Regards,
    PolkThug
  • mrmusicman
    edited June 2004
    superbrett,
    that is decieving, nice job with the risers how does that sound compared to the center being on top?
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    JL Audio 300/V2
    2 -10" Treo Subs
    Sirius Sat radio
    Ipod connection
  • superbrett
    edited June 2004
    I think it sounds better myself, I positioned it upside down, so it angles upward.
    It wouldn't fit directly on top of the TV.
  • gacole2000
    gacole2000 Posts: 255
    edited June 2004
    Is that a Panamax 5100 I spy?
    Nice set up!
    Greg
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • superbrett
    edited June 2004
    Good eye....the pics are blurry and ya still pulled it off!
    I really like the Panamax...I don't have a problem w/power being dirty, but the surge protection is second to none IMO.
  • gacole2000
    edited June 2004
    I concur.
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2004
    Very nice looking brett. A good investment for audio. I wonder though, why not calibrate with an SPL. Maybe your ears are better than mine but I really did notice that my HT sounded better after I calibrated everything.
    Enjoy your gear man!
  • superbrett
    edited June 2004
    Quite simple really, Reel. I don't have an SPL, and when I went to Ratshack.....they didn't either.
    I'm sure eventually I will own one, but right now I'm working alot anyhow, and the last thing I want to do when I get home is jack around w/that.
    My Harman Kardon remote has a bulit-in SPL, which get's me fairly close to what it should be, but I can't tell how accurate it is.
    Ah well...something to look forward to I guess.
    El~Brett-o`
  • scottvamp
    scottvamp Posts: 3,277
    edited June 2004
    Very nice setup, Brett. That SVS looks killer. Can't wait to get mine.
    Please raise those rears a couple feet. :eek:
