Magni-Max Subwoofer no Sync
underwooda
So, I turned off the breaker to instal garbage disposal. When I turned the breaker on my sub is not syncing at all. I’ve never had to sync this unit. When I plugged it in it automatically synced. I can see the Polk WiFi channel is up. I just can’t sync the sub. I never get a chime or sound from the sub syncing. I’ve disconnected power and waited several times. I moved the sub closer. The green light just blinks relentlessly. This is the second unit I’ve owned. The first one the subs popped as soon as it synced. This one has lasted about a month. I’m starting to regret going with a Polk.
