Anyone using IsoAcoistics Gaia on SDAs?
I'm on the fence about ordering these feet for my SDA-2As. A few of the plastic nubbins broke off of the bases, and they rock back and forth.
The speakers are on a hardwood floor on bouncy 2x6 framing.
I could either:
-use these feet
-keep the stock bases and put new felt or something under them
-use spikes with discs
-thru bolt to the floor with a nut in the basement, maybe with some sort of gasket between (but then I can't play with positioning)
What do you guys think would have the best effect?
I tried doing a forum search, and only found @bc6 with the gaia feet on sda 2.3
Thanks!
  • You might look at Herbie's Audio Lab array of products for speaker isolation. Most folks get best results with spikes, but in my situation (a wood floor above a basement) I found that decoupling the speakers kept reverberation from moving through the floor and muddying the sound.
  • spongebobsquarepants
    edited September 2020
    Went on the Herbie's site, and have the "Way Excellent II Turntable Mat" in my cart now :D . The herbie spikes are interesting with no hardware. Seems like we have a similar floor situation @Jazzhead ...what method/products did you use for decoupling?
  • JayCee
    JayCee Posts: 1,509
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Sponge...:
    I have four Big Fat Dots under my RTA-12's - between the speakers and the stands. When I tried the Dots they made the 12's come to life, especially in the lowest frequencies. I have four Little Fat Gliders under the stands to decouple from the floor. In my situation it sounds very good. The wood floor thing can be a problem.
    F1nut Posts: 52,105
    I tried some Herbie's dot things under my TT. Didn't do a damn thing, sent them back.
  • I recommend the Gaia’s 👍
    Thanks for the input everyone.
    Just ordered two sets of Gaia III.
    I'll update when I get them with install process/ thoughts on performance.
    Got the left channel all set up. The 8mm tee nuts had 90° bevels for metric flat screws, so I "machined" them to 82° so I could use 8-32 stainless screws I had left over from the hurricane nut project.
    The gaias are a lot springer than I thought! You can move the speaker a few degrees in any direction.
    I'll update once I get the other speaker done on how they sound.
    xschop Posts: 5,561
    Those isolators look just like a set of poly engine mounts I used to make.
    Looks like a nice install you did.
  • Thanks @xschop !
    I finished the other speaker today...
    They don't sound too dramatically different to me..
    The bass seems to hit a little harder, in a good way.
    The height from the floor is within a quarter inch of stock.
    Anyone have any use for free sda-2a bases in poor condition? :D
  • Gardenstater
    Gardenstater Posts: 4,841
    I doubt that it's your imagination. Do you feel less vibration of the floor through your feet now?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • I got a chance to crank it up with a record I'm really familiar with, and it sounds very different at higher volume. The bass is a lot clearer and puncher.
    Seems like a great fit for my bouncy floor situation.
    The floor is so bouncy that before I put the turntable on a shelf, it was nearly impossible to walk in the living room without skipping.
    Here's a photo of the setup with the new shoes.
    xschop Posts: 5,561
    Sounds like you've accomplished your goal.
