Searching crossover LSI9
I'm looking for a crossover for polk audio lsi9.
If someone has one and sells it to me.
thank you
    F1nut Posts: 52,165
    You don't need to replace the entire crossover if yours has damaged components as they can be replaced.
  • cmartinez
    with the transport the plate broke, also the main coil. :-(
    a shame
    F1nut Posts: 52,165
    Ouch
    F1nut Posts: 52,165
    Have you checked eBay?
  • cmartinez
    Yes, but at the moment there are none.
    Would also be one of lsic?
  • krazypolk
    cmartinez wrote: »
    What are you trying to say in your second sen?
  • cmartinez
    I do not know if it is worth tremien that of lsic for lsi9
  • cmartinez
    Crossover of LSIC works in a lsi9?
    in case they sell any
  • krazypolk
    So basically you're wondering if you can replace the lsi9 crossover for one from an lsic?
    I don't know the answer to that. Perhaps someone else can chime in.
    F1nut Posts: 52,165
    No, it's a different crossover.
  • cmartinez
    yes is that.
    thanks you
  • krazypolk
    That's bad news for you @cmartinez because I have a parts lsic and it does have the crossover.
    F1nut Posts: 52,165
    Tell ya'll what, I could be wrong, so check with member VR3 as I'm sure he will have the definitive answer.
    VR3 Posts: 29,631
    Crossover is different between the lsic and lsi9
    F1nut Posts: 52,165
    Thank you Trey.
    VR3 Posts: 29,631
    edited September 2020
    Imo, you can fix that crossover pretty easily, the wire that is broke off, separated from the board, you can drill a hole in the board it broke from in the same trace, scrape off the coating and solder in place.
    The broke inductor lead, scrape off the coating off each end, bend a hook then insert a small wire between them, apply hot glue to reattach inductor
    Maybe take half a hour
    F1nut Posts: 52,165
    I'm seeing multiple dents/gouges in one inductor. If the coating is damaged, highly likely, that would not be good.
  • cmartinez
    cmartinez Posts: 24
    the crossover of the LSIC is the mod re3610-1
    the crossover of the LSI9 is the mod re3608-1
    With the krazypolk crossover and its mainborard, isn't it easier to repair?
    using your coil?
    Aesthetically they are very similar.
  • cmartinez
    crossover lsic "internet"
  • cmartinez
    VR3 wrote: »
    Wish you were here. :-)
    I do not know anything about electronics .... although I will try.
    F1nut Posts: 52,165
    If Trey says they are different you can take that to the bank!!!
    VR3 Posts: 29,631
    Yeah they are similar but different, the tweeter network and lower frequency driver portion of the circuits are notably different.
    You could, in essence rob your lsi9 board to possibly populate onto a lsic board but i suspect fixing or finding the right crossover would make more sense as the layout is pretty different.
  • cmartinez
    VR3 wrote: »
    Tomorrow I will try what you have told me about the holes. With a dremel.
    I'll put a photo.
  • cmartinez
    Will this work like this?
    Or can a bridge be made in the broken area?
    pitdogg2 Posts: 27,576
    I don't think that is savable. Each one of those wires is coated in enamal so not to short on one another. No way to solder enameled pieces.
