MMC6500 tweeter fuzzy
balaraform
I just installed this componets system in my car. I am running a JLe3400 which puts out 75x4 to my speakers. I only installed my front door speakers the rear are still factory, I was told by my installer that this was allright to keep the factory and upgrade the front. But now the highs on the passenger side have a fuzzy sound in them and kinda cracking. I think I might have blown the speakers but why wouldn't the driver sides go too? Can you buy a new tweeter only? What should I do.
You will have better luck in the Car Audio section! (Bottom of main forum page)
Good Luck!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
