Any opinions with buying these for my first Polk Theatre?
I've been researching a living room theatre system and have decided on this set up. Not a large living room, and looking for some decent sound.
Fronts - Polk Monitor 60 Series
Center - Polk CS1
Rears - Polk RTi A1
Subwoofer - Klipsch -R-12sw
Receiver - Denon-AVR S750H
Thx for your input!
    Tony M Posts: 11,827
    I'd say you'll have a great system to enjoy your movies with. ;)
  • BlueFox
    BlueFox Posts: 15,250
    Don't forget the interconnect, speaker, and power cables.
  • afterburnt
    afterburnt Posts: 7,892
    Just curious, why did you choose the RTi's?
  • rooftop59
    rooftop59 Posts: 8,120
    SoCalEd wrote: »
    Center - Polk CS1
    Rears - Polk RTi A1
    Thx for your input!
    That is similar to my first HT (though slightly better), and it did not take long at all for the upgrade bug to bite. Depending on your personality, you might be happy for many years OR you might become quickly unsatisfied. Know thyself and all...
    For HT applications, the center and sub are the most vital. That is a solid sub, but I am curious how much it’s going to cost. If it’s close to $500, SVS or HSU offer a much better value. As for the center, that was the first one I owned, and it’s pretty much the worst center channel I have ever owned. Very bright sounding, not much bass. When I upgraded to the CSi3, that was much better. I would try to find at least a CS2, but would recommend moving up the chain to the rti or signature series if possible. And I agree that RTi for surrounds is an odd choice. Go cheaper on surrounds and use that money for center or sub.
    Game Room 5.1.4:
    Bedroom 2.1
  • Milito
    Milito Posts: 2,003
    I had Polk Monitor 60 Series before I bought some S55's. I also has a CS1 and it was bad. I upgraded to a CS2 and yes it was an improvement. Do at least that and higher if you can.
