CSi5 Buzzing
My CSi5 has recently developed a buzzing a higher volumes. I have the speaker under my TV on the angle side and the buzzing is from the right speaker. The left speaker and tweeter still sound great. Not sure if its a speaker issue or crossover....is there any replacement parts or am I stuck buying a new center?
If life had more tubes it would be a lot smoother.
    txcoastal1 Posts: 13,519
    I used a can of Raid once to stop the buzzing...
    Sounds like a blown tweet and/or crossover component. Have you pulled out the board?
    Post pics
  • I actually just swapped the woofer side to side and the buzzing followed. Followed that test up by removing the suspected dead woofer and the buzzing went away... shocked a woofer just gave up the ghost without any warning. Its always been run on my Sunfire signature 7x400 amp so clean powered wasn't an issue. There is one woofer for sale on ebay so I guess thats the next step.
    F1nut Posts: 52,101
    Doubt it's the crossover. You could try swapping the left and right drivers. If the buzz follows you'll know what the problem is.
  • F1nut wrote: »
    We must have been typing at the same time. What are the odds that Polk has a replacement woofer for this speaker?
    F1nut Posts: 52,101
    Not sure, you'll have to call Polk.
  • rooftop59
    rooftop59 Posts: 8,120
    I have seen several CSi5s pop up on eBay for less than $100 over the years. That’s probably they better way to go. Then you have backup drivers...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59 wrote: »
    I've only seen the CSi3 for under $150 myself. Polk has new drivers for $60 plus shipping and tax and that's a new drivers vs $40+tax for a used one on eBay.
