HTS10 power light flashing red after playing normally for a few seconds
I just got an HTS10 and a new Denon AVRS650H receiver. I have the HTS10 set to auto power cycling and I've tried the Denon in both LFE and LFE+Main modes. My front speakers are set as small. The subwoofer is definitely getting signal.
Whenever I unplug then plug in the HTS10, the power light turns green, it plays for a couple seconds (sounds fine) and then it emits a couple of thumping noises and the power light starts flashing red and stays that way indefinitely.
The manual doesn't mention this behavior at all. I'm not really sure what to try next. Any ideas?
  • [Deleted User]
    Hello,
    It's probably best to contact the seller and explain what's happening, or Polk via their customer support line: 1-800-377-7655 select option 1.
  • jessgaerlan
    same problem with my HTS12 😞
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,369
    Hello,
    Welcome to Polk's forum. Could you elaborate on what you are experiencing? How is it connected to rest of your system. Did you just get it? Was it working fine and then stopped?
  • Stemito
    Stemito Posts: 1
    I have the same problem and its driving me nuts. It started blinking red a couple of days ago after running perfectly in the last 4 years. Tried everything I could. I also tried to contact Polk audio support with no luck. I read from another user that he solved this issue by running a firmware they provide him but I cant find the file anywhere in the whole internet. Im desperate
