Signa S2 turns itself off
repairman1946
Signa S2 turns itself off, when in mute mode, after a few minutes.
Is it possible to increase the time?
Can you just disable it completely?
So annoying. It even shuts itself off without being muted. If there is no input for a long time, it shuts off. There needs to be a software update that allows the ability to disable it.
