Russian 6n23p Saratov plant 1975 silver shield single wire getter
muncybob
These can be had but have gotten very expensive. Let me know if you find a pair for around $100 or a quad for $200. Really only interested in the 1975 tubes.
Yep, my name really is Bob.
Have you tried the Voskhod? I was blown away with the 6ak5 Voskhod I had.
https://www.ebay.com/itm/RARE-10-6N23P-E88CC-6922-Voskhod-1971-1974-Getter-on-the-wire/114156576790?_trkparms=aid=1110012&algo=SPLICE.SOIPOST&ao=1&asc=20200818142651&meid=62cc818c81b640b8a51c2383645c8edd&pid=101196&rk=5&rkt=11&mehot=none&sd=112963776257&itm=114156576790&pmt=1&noa=0&pg=2047675&algv=PromotedSellersOtherItemsV2&_trksid=p2047675.c101196.m2219
seen this one?
https://www.ebay.com/itm/RARE-MATCHED-PAIR-6N23P-REFLECTOR-Silver-Shield-1975-SWGP-NOS-Tested-100-/112963776257 -
Yes, those are the silvers I'm wanting....just not $110 each.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Like I said I've turned several on to the Voskhod's and no one has disliked them. They're a gem as far as Russian tubes go.
I've got some Russian contacts I've bought from I'll see if they have any. They are also in Ukraine. -
Cool, thanks. I recall somebody saying they were an unknown gem in tubes, just don't recall which version the article was talking about.Yep, my name really is Bob.
I like the Sovtek 6n30pi, great sounding.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
sorry, I meant 6h30pi.
https://www.amazon.com/Sovtek-6H30PI-Preamp-Vacuum-Single/dp/B01HQYZS4A
E.H. also makes them.
now if you want the best.
https://www.thetubestore.com/russian-6h30p-drAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
The "best" are way out of my price range and even if I thought of spending that kind of $$ the following would leave me out:
Please note that this tube can not be used in place of 6DJ8 or 6922 tubes in other pre-amps; it can only be used in equipment that is designed for it.Yep, my name really is Bob.
Thanks, Marvda I knew that's what you meant. My preamp was actually designed for a 6H30 but he said I could also use a 6922, 7308, or 6DJ8. I am currently using 1950's Amperex 7308 D-getters. Very very nice tube but always wondered what the 6H30 would sound like in comparison. So far I haven't been curious enough to drop the wad they want for the 6H30p-dr, which I'm told is indeed the best of the 6H30's.
Just out of curiosity, what is the difference between the 6922/ 6dj8 and these russian tubes, is the heater current higher? I see a lot of sellers saying they are equivalent. -
The problem with Russian tubes is in my experience and others much more knowledgeable than I have said many are NOT direct replacements for ours because of the way the pins are attached to the internal structure.
see if your pre can run a 7dj8? this is a wonderful sounding tube, it is a drop in replacement for a lot of amps and pres.
https://upscaleaudio.com/collections/vacuum-tubes/products/matsushita-national-pcc88-7dj8
Puritan PSM156
