How can I connect my atrium 4 speakers to the headphone jack on my outdoor projector?
klopes19
Answers
You'll need something to provide the necessary power, usually an integrated amplifier or all-in-one receiver. Then use a cable that has the appropriate stereo male phono plug on one end and RCA-type connectors on the other end. This will link the projector to the "aux" input on the receiver. Then use speaker wire to connect the receiver to the speakers.
Ideally you'll want to use the L and R line out RCAs on the projector instead of using the headphone jack.
Make and model of your projector? Sorry it’s a little off topic
Thnx TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
we need some more info to help you out buddy...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
