Why my sub only work with just one pair of input
I have a problem with my DS7200SW sub.
when I try to hook up all five input wire there is only one pair of negative and positive input work.
I try to hook up all the negative and for the positive wire I just put them together to the positive input that work. That will give me all the sound for five speaker.
Answers
    F1nut Posts: 52,146
    While the problem could be with the amplifier inside the sub it could also be that the problem is inside the preamp/processor. That is an old unit and no parts are available. I'm afraid it's time for you to shop for some new gear. You can use the speakers, but you'll need a new AVR, sub and source player.
