SRS with Dayton drivers
Any thoughts on this? Seller says he bought the speakers new and replaced to original drivers with the Dayton 4 ohms and that they sound good.
Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
  • Nightfall
    Nightfall Posts: 10,083
    I wouldn't bother. They're going to need ~$800 worth of drivers including time spent searching for them, waiting for shipping, sending any back with magnet shift, selling all the Dayton drivers... it's going to take time and work to get them where they should be. Maybe if the price is really good and you don't mind the leg work?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    They are 1.2 TL's because they have SL 3000 tweeters and a couple of RD0 198's. Criminal what they did to them.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • aprazer402
    aprazer402 Posts: 3,449
    I'm betting he's not the original owner. Hoping he's not anyway. If he bought these NEW, he probably paid close to $3,000.00 for them. These were an audiophile purchase. If so, being an audiophile, he should have enough sense to know what he had and not to $%^& 'em up. I agree with Nightfall wait for another pair.
    F1nut Posts: 52,164
    What a disaster.
  • ptrooper
    ptrooper Posts: 501
    He might have the originals as spares :/
  • ratpin
    ratpin Posts: 99
    ptrooper wrote: »
    He says he has them
  • westmassguy
    westmassguy Posts: 6,850
    Run, don't walk away.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,933
    2020! What else will we see!
    This falls into the category of something that can't be unseen.
    Harry / Marietta GA
  • invalid
    invalid Posts: 1,552
    They probably don't sound very good that's why he is selling them.
  • honestaquarian
    honestaquarian Posts: 3,260
    Yeah
    What he 👆🏽👆🏽said!!
  • Gardenstater
    Gardenstater Posts: 4,858
    I'm curious (only a little) what the price is, but this definitely gave me a headache.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • DaveHo
    DaveHo Posts: 3,583
    ratpin wrote: »
    ...they sound good.
    What do you guys think?
    I think the seller is lying through his teeth. Unless he is letting them go for a hundred or two, run away, fast!
    pitdogg2 Posts: 27,572
    edited July 2020
    Just going to throw this out.
    IF they're truly 1.2tl then they used 4 each of mw6503 and mw6511. Now those drivers had different parameters so if they are all the same 4ohm drivers with the same parameters then right off they're wrong.
    MW 6503 1.82 5.24 N 3.55 E - 3N/M 6.54 Ohms 29 Hertz
    MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.13 Ohms 29 Hertz
    Run away do not look back.
  • ratpin
    ratpin Posts: 99
    I mainly found these looking for an Adcom GFA-555. Hes selling the speakers together with amp and tuner (both adcom 555) for $1500.
  • monepolk
    monepolk Posts: 1,154
    Wondering how he ran these with mono amps.
    xschop Posts: 5,664
    monepolk wrote: »
    Without the interconnect?
    Those would make a great PA system.
  • michaeljhsda2
    And because he didn't use an AI-1 transformer, he ruined the Adcom's! Wow, unbelievable.
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 52,164
    monepolk wrote: »
    With disastrous results.
    Viking64 Posts: 7,710
    These speakers are unique in that their sweet spot is 3 miles down the road and then off into the woods a few hundred yards past a rusty 1978 Mercury Monarch.
  • ratpin
    ratpin Posts: 99
    Could you please elaborate on that?
    F1nut Posts: 52,164
    You cannot use mono blocks, dual mono or non-common ground amplifiers with SDA speakers without using an isolation transformer on the SDA cable. Damage to the speakers or amp(s) or both will occur otherwise.
  • Nightfall
    I'd be leary of the crossovers with this new info.
    afterburnt wrote: »
  • invalid
    You might be able to strap the negative binding posts together with those amps, but looking at what he's done to them I think not.
    Some Adcom amps had a bad problem with caps leaking and ruining the boards. If that happened it may never of been a speaker problem.
    If he ran them with no cable there should never have been a problem. Only when the standard cable is used is when problems arise.
    I believe it may of been early gfa 565 monos that were problematic.
  • motorstereo
    motorstereo Posts: 2,395
    My guess is that relay-less Adcom sent dc to the original drivers and that's why the junk replacements. Burnt voice coils on the originals, possible crossover issues now and a fire hazard Adcom amp. I see a pile of parts for way too much money.
