65" Samsung Curve Sits too Low!
tophatjohnny
tophatjohnny Posts: 4,189
edited June 2020 in Electronics
Sits too low for the new Center Speaker That I just bought. The TV is about 6" too low so I am looking at something like this https://www.amazon.com/PERLESMITH-Universal-Premium-Adjustable-800x400mm/dp/B07KFD7QPZ/ref=sr_1_28?dchild=1&keywords=Leg+raiser+for+65"+curve+tv&qid=1593128243&sr=8-28#
I'm not good at stuff like this and hoping someone here has been in the same situation and has done this before. I have this one I shared in my amazon cart but haven't ordered it yet. Any help???? Thanks either way
  • Unknown
  • tophatjohnny
    Thanks Ivan. I'm wanting the tv's bottom edge to be just over the front of speaker so looking at other possibilities like the one I have in my cart but maybe better?? Mo betta!?!?!?
  • Unknown
  • rooftop59
    rooftop59 Posts: 8,120
    I yes this to stand my tv on my huge def tech center channel:
    https://www.amazon.com/gp/aw/d/B077MJZ6ZG?psc=1&ref=ppx_pop_mob_b_asin_title
    Game Room 5.1.4:
    Bedroom 2.1
  • tophatjohnny
    I just talked to a guy in Syracuse and he's making me a riser perfect for the job.
  • joecoulson
    joecoulson Posts: 4,985
    Sweet
  • tophatjohnny
    Syracusetvrisers.com
    Owner spent a while on the phone with me this morning and sealed the deal for just the right build for the new center I have coming. Will be a couple of weeks before it all comes together . Looking forward to it. 🎶
  • DaveHo
    DaveHo Posts: 3,584
    edited June 2020
    At one time I built a riser for my TV so I could place the center below. It was solid on the top, sides and most of the back. It had a very negative impact on the sound. Center sounded like it was in cave. Kind of like it was horn loaded. Currently, I've got my center on a stand out in front. Do you have room for that?
  • tophatjohnny
    DaveHo wrote: »
    I hear that brother and I am working on a solution to avoid this from being the case. Solid sides won't be happening but not sure if we'll go large football shape openings or just go with 4 heavy duty legs that leave an extra inch above the center which will be out from the top 1/2 or so anyway. Think I'll be fine but I see how you ran into that cave like issue. Thanks for the heads up.
  • BlueFox
    BlueFox Posts: 15,250
    The center for my 75” TV sits a few inches above the TV bottom, and I never notice it. However, it helps to make the audio actually seem like it is coming from the TV versus being close to the TV.
  • tophatjohnny
    Syracuse TV Risers came through like a Champion company. The build is solid as a rock and looks great with the stand we already had. I did apply 1 sheet of Noiko solutions sound deadener to each of the sides and another 3 sheets to to top side (facing down) just as a precaution . overkill?? Yeah maybe. The matching Aurum Cantus center speaker will be delivered next week and takes up a good portion of the opening.
    This will be the first "real" center speaker I've ever owned. Looking forward to it. Hope this helps someone looking for a solution similar to what I needed done.
  • tophatjohnny
    I referred to the sound deadening material as Noiko when I realized it is Noico. I used Dynamat in the past and like this stuff better. Plus it's not a costly.
  • rooftop59
    Hey looks good Johnny! What model Samsung is that buy the way? I was just looking a a 65 Samsung curved this morning...
    Game Room 5.1.4:
    Bedroom 2.1
  • tophatjohnny
    rooftop59 wrote: »
    Im not sure it was purchased at Costco a few years ago. Its been a great set..65"
