how to remove a in ceiling speaker
jpae93
jpae93 Posts: 1
Hello, I have two LC80i that are in ceiling that need to be removed. Does anyone know to do this? I have removed the 4 screws that go into the rotating cams, but its still stuck to the ceiling tight. I have tried a tip that was posted in this forum about reinstalling the screws and trying again to remove but that did not work either. Is this a permanently installed speaker? Please help.
    VR3 Posts: 29,641
    Good chance it has formed a bond with the paint, carefully put a blade between the ceiling and the speaker basket
  • mak99
    mak99 Posts: 362
    I just had a similar issue when I replaced some 80 F/X RT's with 80 F/X-LS's. Try this:
    • reinsert the screws, maybe about halfway back into the screwholes.
    • lightly tap upwards on the screw, which should help jar loose the clamp from the gyp board (since the screw threads should now be fully engaged on the cam/clamp)
    • while you are unscrewing, see how much "play" is in the screw. As the cam moves upward along the track, the screw should only rotate back-and-forth a few degrees before you feel it hit the sides of the track.
    • when the screw/cam finally can rotate about 90 degrees back-and-forth , the cam should be in the top section of the track, where it can now "fold" back into the speaker housing and allowing the speaker assembly to be removed straight down from the ceiling.
    If I get a chance later today, I'll post up pictures of my RT's with the cam in various positions to better explain the above.
    On a related note, if you are installing brand new ceiling/wall speakers, I would completely tighten/untighten each screw/cam assembly before installation, as doing this will help "loosen things up" so that it's a bit easier to install.
    Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
    Viking64 Posts: 7,722
    edited July 2020
    I'll get it for you. :)
