PSW505 not powering up?
ffwest197
I have a psw505 that’s not powering up? I’ve had it several years, was working great now nothing. My question is if the fuse is blown will this cause the unit not to come on?
Yes, but it’s likely not the fuse. The amp has failed and will need replaced.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
I checked fuse which is fine. Is there a way to check to see exactly what’s wrong?
If you are an electronics tech with expensive test equipment, then sure.
Subwoofer plate amps are very Expensive to fix and generally not worth it. This one would work fine but the enclosure might require a little modification, but you can get a whole new sub for not much more:
https://www.parts-express.com/dayton-audio-spa250-250-watt-subwoofer-plate-amplifier--300-803Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Check the subwoofer level in your avr. If it’s too low it won’t trigger on the sub at low volumes.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
