Received my ADCOM GFA-7605 from Fed Ex!
hamzahsh
hamzahsh Posts: 439
edited May 2004 in Electronics
At exact 12'0 clock the guy from Fed Ex came to my door to deliver my new 5-ch ADCOM GFA-7605 then I hooked all new Monster THX Ultra Audio Interconnects to it which I purchased 2 days ago from Best Buy I paid 50% off 'cause I work there. I'm so glad now that I have separate AMPs, first I bought NAD C272 for especially for 2-ch music and now Adcom GFA-7605 for HT. I use both when I watch movies. I use only NAD for 2ch for music.
GFA-7605 Five Channel Home Theater Amplifier Features!
* Power delivery of 125 watts x 5 channels
* New Adcom "Power Rig" circuitry
* New Adcom "F.A.T." fast analog transform technology
* Precision-matched devices used throughout the signal path
* Fewer gain stages improve signal reproduction accuracy
* Huge custom-designed toroidal transformer provides better regulation and greater peak current capability
* Independent channel-specific mono power supplies
* 100,000 micro farads of power supply capacitance
* Independent thermal-overload and distortion LEDs for all five channels
* Large, independent, internal heatsinks for greater cooling capability of output devices
* Cooling vents for greater efficiency and cooler operation while driving low impedance loads
* High-quality, gold-plated 5-way binding posts
* High-quality, gold-plated RCA jacks
* 12-Volt trigger on / off
* Heavy-gauge, anodized aluminum front panel
* Powder-coated, baked chassis and top cover for greater durability
SPECIFICATIONS
* Power rating: 125 Watts continuous x 5 (8 ohms 20 Hz-20 kHz, all channels driven); 175 Watts continuous x 5 (4 ohms 20 Hz-20 kHz, all channels driven)
* IM Distortion (SMPTE) : 0.075%
* IM Distortion (CCIF) : 0.025%
* THD + Noise: 0.02% (125 watts into 8 Ohms at 20 kHz); THD + Noise: 0.06% (175 watts into 4 Ohms at 20 kHz)
* Frequency response (1 Watt into 8 Ohms, 10 Hz - 20 kHz: +0,-0.25dB
* Power bandwidth (-3d B) : 1.5 Hz - 65 kHz
* Dynamic Headroom (at 4 ohms): .2.00 dB
* Signal-to-Noise ratio ("A" Weighted, 125 watts into 8 ohms): >117dB
* Gain: 29dB
* Input sensitivity: 0.1 volts (for 1 Watt); 1.1 volts (for 125 Watts)
* Input impedance: 48k ohms
* Damping factor: 20 Hz - 20 kHz:> 498
* Rise time (5 kHz, 120 V peak-to-peak square wave, 20-80%): 6.0 µS
* Power consumption (continuous, all channels driven): quiescent, 116 VA; maximum: 1500 VA
* Dimensions: 17" wide, 14" deep, 5" high
* Weight: 42 lbs.
* Shipping weight: 48 lbs.
* Manufacturer's limited warranty: five years parts and service
I will watch ROTK tomorrow!
:D:D:D
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
Post edited by hamzahsh on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2004
    Originally posted by hamzahsh
    At exact 12'0 clock the guy from Fed Ex came to my door to deliver my new 5-ch ADCOM GFA-7605 then hooked all new Monster THX Ultra Audio Interconnects to it and its ready to rock.
    So did the FedEx guy bring the Monster stuff with him or did you already have that??:D??
    I wish my delivery guy would Hook my stuff up for me. I tried to get the UPS guy to do that with an amp I recently bought, but he wouldn't do it..guess I should have used FedEx :D:D:D ...
    man I'm a jackass...:D
    Congrats on the new gear...
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2004
    Sorry I forgot to put "I". Guess I'm so excited to skip words. I'll write a review on it. I've edited my post. Thanks Polkmaniac!
    Anybody who owns Adcom stuff! let me know what do you think about it.
    Now I'm into separates!
    NAD C272 (2-ch Amp)
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2004
    i love my 7607 it is great but i have to warn you if you blow a fuse you have to rip the whole unit apart to change the one on the negetive rail. i was at my local shop and was told this by the repair guy. and fuses arnt covered under warentee. but this is a great unit solid and sounds great.
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2004
    That is a very impressive line up! Good job.
    quick q...
    How do you like your Yamaha RX-V1400 pre/pro?
    HBomb
    ***WAREMTAE***
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2004
    Congrats on the purchase. I love Adcom amps. I've never had any problems with any of their amps.
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2004
    quick q...
    HBomb
    Yamaha RX-V1400 is a state-of-the-art pre/pro. If you have this receiver you don't have to get a pre/pro. This receiver itself is one of the best pre/pro. It does everything for you. All current sound formats with Yamaha proprietry DSPs, DPLIIx. YPAO Yamaha Parameteric Acoustic Calibration. Dual 32bit DSPs.
    Component switching and upconversion. High quality 24/192 AKM DACs are used. I was told by people the sound quality of this receiver matches with the $2000-3000 range.
    AKM 4382 DACs for FL & FR channels
    AKM 4358 DACs for the rest of the channels.
    Now Anthem AVM20 pre/pro uses AKM 4382 DACs for all channels where Yamaha 1400 uses only for 2-channel. Check the price on Anthem AVM20 pre/pro and check for Yamaha 1400 according to www.alexhardware.com
    look at the IC database sheet on the website it tells you what DACs, DSP and other chips are used in Receivers and Pre/Pros.
    DIRECT STEREO mode in my Yamaha 1400 is outstanding similar to PURE DIRECT mode in other receivers. When I use this mode with my NAD C272 Oh! what a sweet sound comes from my RT800i and solid midrange and accurate tight bass. No need for subwoofer in music! If you like neutral to natural or in other words accurate sound Yamaha 1400 is the receiver for you. Yamaha 1400 is a steal for what it sells! :D
    Now I have a solid Home Theater System! the only thing lacks in my system is the big-screen TV and then I'm done! it
    NAD C272 (2-ch Amp)
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2004
    How the fuse died on your 7607?
    NAD C272 (2-ch Amp)
    VR3 Posts: 29,398
    edited May 2004
    There are so many fuses in Adcom amps for protection reasons...its not all THAT hard to do...
    Plug something up while its on...
    Power surge (rare)
    Etc, easy fix...
    I own some Adcom gear (currently 2 gfa-545), use to own 5 2 channel amps, but I have unloaded alot of them for various reasons. They are solid amps...
    Let us know how it goes!
  • HBombToo
    edited May 2004
    Sounds like a great match for my Outlaw. The Outlaw sounds like anything you plug into it;)
    HBomb
    ***WAREMTAE***
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2004
    I'll do the real test tomorrow with ROTK on my Adcom and NAD.
    Well today, I watched Gladiator and during dialogue scenes I turned up the volume around -10 db and what I noticed was the sound is bigger and fuller and same time smoother. The dialogues coming out from my Polk CS400i center channel were perfect. Both male and female voices were accurate. No sign of harshness and strain here. The battle scenes in the beginning and in colosseum were loud and clear.
    Adcom GFA-7605 is a solid amp! for sure.
    :cool:
    NAD C272 (2-ch Amp)
  • goingganzo
    edited May 2004
    a moron pulles a speaker cabble off one of my speakers and shorted it out i was ready to kill him. but the top fuse olny blew and not the botom. to replace the botom fuse you have to take the botom plate off and stand the amp on its front so the cards dangle from the back plate. that is how the servis guy told me to do it and it dont void the warentee. but ti takes over a hour to do all the screws.
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2004
    It means that if someone take all the precautions and use the amp properly then fuse will never die. Well I use my equipment very carefully and I don't have to worry about.
    NAD C272 (2-ch Amp)
