Mounting Polk Audio 5jr's
SyntheticSymmetry
edited April 2020 in Vintage Speakers
I have an old but pretty pristine looking pair of 5jr's I'm getting a setup for, and I would need to have them up on the walls of my living room, otherwise the sound would be completely blocked. What sort of wall mount would work best for them? Would I need to drill into them to have a sturdy hold? I assume theres a ton that I might overlook here so I wanted to ask the pros!
Best Answer
    F1nut Posts: 51,771
    Answer ✓
    I don't think I could have them both flat to the wall and angled at the couch, unless they were sideways above my television. Should I try to search for some kind of adjustable mount?
    And thanks for the motivation, xschop!
    These might work if you're dead set on using the 5's.
    https://www.amazon.com/Mount-Universal-Clamping-Bookshelf-Mounting/dp/B01MZE0O8U
Answers
