Advice amplifier
I've got a couple s20's, S60's and a center channel
I haven't been able to find a corner wall mount that will fit so I'm looking to turn them into a 2.1 system and ordering the smaller S10's for my HT.
Any advice on a decent amplifier that is small, powerful and reaches the upper limits of the speakers ??
    The upper limits of the speakers ?? What is that exactly...in your view.
  • jbreezy5
    jbreezy5 Posts: 1,141
    f0cCuS wrote: »
    Budget?
    If you need affordable good quality power check these out on ebay:
    Niles SI-275
    B&K ST 125.2
    Parasound Classic amps are quite affordable new.
    pitdogg2 Posts: 27,542
    weilai reported
  • halo
    halo Posts: 5,619
    edited May 2020
    If your subwoofer has speaker level inputs, a simple integrated amp would do you well for a 2.1 setup. I have a NAD C 316BEE available.
    Newer integrated amps have subwoofer outputs on them but they usually are fixed and cannot be adjusted from the amp, You'll have to adjust the x-over on your sub instead.
