Tweeter help
Can someone tell me if these are Peerless for Polk? Made in USA 55140983 serial on one the others have 5514 too I dont see any hole in the middle if that maters
  • Gardenstater
    Gardenstater Posts: 4,798
    edited February 2020
    I don't know if they were only made for Polk, but I believe that would mean that one was made in the 9th week of 1983. I have a couple 5514s that say made in USA that do have the hole. Not sure what the deal is as far as why some have it and some do not. Mine are 8 Ohms. They apparently made some that were 8 Ohms and some that were 4 Ohms.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,209
    Polk burned a hole in the dome center of most of theirs. Other manufactures used them they were not a Polk exclusive AFAIK.
    mhardy6647 Posts: 35,192
    They were also sold for DIY by Peerless (for many years). KO10DT, available into the early 1990s at least (per old Parts Express catalogs)
    Yes, widely used in 'big name' loudspeakers in the 1970s and 80s in particular. Some of the Singer (?) era KLH loudspeakers (e.g., the 355 Barons) used 'em, as did some b&o loudspeakers and the (at least) regionally famous Cizek loudspeakers. There were others, but those are the ones that leap to mind as I sit quaffing coffee and reminiscing :)
    15127683227_a3c1c18ae5_b.jpgCizek brochure p2 by Mark Hardy, on Flickr
    (borrowed images all, except the Cizek brochure page)
    EDIT:
    Some early Teledyne-era (?) AR speakers, e.g., the early AR-14, used the Peerless silk dome tweeter too (albeit with a 'custom' bezel).
    oh -- in the matter of the "holey Peerless" used by Polk. Yes, my understanding (per @pitdogg2's post above) is that Polk burned the holes in theirs with a soldering iron (at least in the early days).
    The only reason I am commenting on this, and strictly FWIW: I am not absolutely sure that very early (?) Polk products using the Peerless silk dome tweeter had the holes burned in 'em (EDIT: and I just realized that @pitdogg2 mentioned this, too -- sorry for being redundant!).
    I say this on the strength :p of very circumstantial evidence, such as a pair of early Monitor Series Model 10s that are here. These have Peerless(es) sans holes -- but of course I don't know if these tweeters are original or were perhaps replaced in the three-ish decades this particular pair of loudspeakers exisited before I acquired 'em. :|
    11208619575_674f036d9b_c.jpgP1020559 by Mark Hardy, on Flickr
    There's a nice pair of Monitor 9As in the basement -- I honestly can't remember if their Peerless tweeters are holey or profane ;)
  • I believe the hole was put into the domes to allow air pressure to equalize between the inside and outside of the domes. This became especially important when the speakers were sent via air cargo shipments.
    Interesting! I had always assumed it was for resonance control (but that was, at best, a SWAG).
    That is what I was lead to believe as well.
    Thanks Ken
  • laptop44
    laptop44 Posts: 11
    Thanks to all for their input. These are on Craiglist local and I was wondering if I could use them to replace the SL2000 in my 10B. Would they fit? I have a set of 10 A with the peerless and prefer the sound from the A over the B.
  • Well it might not be what you want to hear but I found that I prefer the sound of the Danish ones over the USA ones (with my limited sample size of 2 pairs of tweeters). I "believe" the Danish ones all start with 7714..... but I'm not 100% certain.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    They are slightly smaller in the bezel and the cut out for the sl2000 tweeter will not work for the Peerless.
    Not a good idea to use them in the 10b
    That is correct
    IIRC the danish also have flat sides on the magnet.
  • Ok will get the 194 instead. Thanks to all!
    F1nut Posts: 51,930
    laptop44 wrote: »
    That's your best choice.
  • pitdogg2 wrote: »
    That is correct
    I've seen some early 5514s with the flat. Chris has one (1980 mfg. date) and posted the pic in my Peerless Tweeter thread.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
