Re: mounting components on x-over board
I'm still in the component-gathering stage of re-doing my Monitor 7s, but I have questions brought about by viewing x-over photos on this site.
What is the foam-looking material seen under components on the original x-overs? Should it be re-used? If not, then what is utilized?
Also, I have read past discussions, but what is current consensus on securing components to board? Zip ties? Hot glue?
Thanks in advance for your response.
  • Navy_Goat
    Navy_Goat Posts: 375
    edited February 2020
    Zip ties + 3M foam double sided tape is what I used. It worked well enough. Hot glue is another option, but I don't have a glue gun. Come to think of it my wife might have one, I should ask her.
    Edit: Just looked at my Amazon account. Looks like I used Scotch branded mounting tape.
    Scotch Brand 051131762718 Scotch Foam Mounting Tape, 1/2-inch x 150-inches, White, 1-Roll
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • classic carl
    slow_polk7 wrote: »
    Zip ties? Hot glue?
    I've used both.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
    F1nut Posts: 52,167
    3M VHB tape provides a bit of a cushion and an extremely high bond. Zip ties are still a good idea, call it insurance. Hot glue doesn't bond well to the slick nature of film/foil capacitor covers.
    pitdogg2 Posts: 27,581
    I personally have only used hot melt glue in the inductors. Not a lot just a good bead along the top and inside across the hole. High bond tape and zip ties on caps. Never hot melt resistors, I've also never used foam or dual sided tape. I just raise them off the board just a bit for air flow as they can get very hot. They do need some air flow to dissipate heat IMO.
  • slow_polk7
    Thank you gentlemen for your helpful and timely responses.
