The difference between polk's 5.25 different woofers
Hello,
I have an old R10 pair of speakers which I really love.
Unfortunately, one of the speakers broke, and I would like to fix it.
For that, I was searching for a replacement kit of the original rd0514 woofer.
Now, I could not find it, but instead I found some of MW5530, MW5531 and MW5532, which the seller claims they are all the same in weight and sound quality, while the only difference is the cone color and whether the magnet is shielded or not.
It sounds pretty odd for me, and that's why I am asking you here-
Could you confirm that if I will replace my old rd0514 with a newer MW5530/1/2 - my speaker is going to sound the same as with a new rd0514?
Are the differences between the all 5.25 models are really about cone color etc. ?
Thank you!
Thank you!
Fit, form and function they are fairly generic to each other. Cosmetics may be a bit different, cone color, plating color of the basket etc...
Putting them in your system should result you in a speaker system that doesn't sound any different than it did originally. Just my opinion, from practical experience.
John
