PCM or Bitstream
Recently purchased a Magnifi Max which I have connected to an LG C9 tv set, I am also using an Amazon Firestick. Our local cable/internet provider has gone completely wireless so everything streams through the Amazon Firestick. I have two questions:
1) The LG TV will either output audio through the HDMI cable in PCM or Bitstream. Which is the best to use. When I have the TV set to output PCM the audio seems louder but the Dolby light on the front of the bar is not lit. When I have the TV set to Bitstream the soundbar volume drops but the Dolby light is lit.
2) Currently I have the Firestick plugged directly to the TV. Is it best to have the Firestick connected directly to the TV and use HDMI arc or plug it into the Soundbar?
  • rooftop59
    rooftop59 Posts: 8,120
    Both questions are just trial and error me thinks. Which options sound best and which are most convenient? Sound wise there shouldn’t be a huge difference either way but experiment and find out and let us know!
    Game Room 5.1.4:
    Bedroom 2.1
