AMP Recommendations
I have a YAMAHA HTR-6180 which pumps out 105w/channel. I can use that to power my surrounds (Monitor 70 series II) and rears (Monitor 60 series II). I need to add an amp to power my fronts, RTI A7 and CSI A6. Looking at a 3x200 amp. Any recommendations?
Projector - Optoma CinemaX P1 | Screen - Elunevision 120" Aurora 8k Ultra Short Throw NanoEdge
Media - HTPC: 120 TB Movies, Nvidia Shield | AVR - Denon AVR-X3700H | Amp - Outlaw 5000, Outlaw 2200 x 3, Outlaw 2220 x 2
Front Spkrs - Polk Audio RTiA9 | Center Spkr - Polk Audio CSiA6 | Surround Spkrs - Polk Audio RTiA7
Rear Spkrs - Polk Audio RTiA5 | Atmos - Polk Audio RTiA1 | Sub - HSU VTF-15H MK2 x 2
«13
    Clipdat Posts: 13,105
    edited December 2019
    Parasound usually pairs up well with the RTi series. The A31 is 3x250w.
  • rooftop59
    rooftop59 Posts: 8,120
    That parasound is probably close to the cost of all his speakers and receiver combined...A more budget friendly option is outlaw audio monos: https://www.outlawaudio.com/mofcart/cmny2019.html
    Even cheaper option is an outlaw 5000, use it to power everything but 2 speakers.
    Game Room 5.1.4:
    Bedroom 2.1
    Yeah, I wasn't sure if buying new or used. Decent deal on the A31: https://www.ebay.com/itm/184076680553
  • rooftop59
    Clipdat wrote: »
    That is a great deal!
    Game Room 5.1.4:
    Bedroom 2.1
    Yes, assuming the seller has the original box.
    Edit: He doesn't: "I no longer have the original box but will pack up extremely well for safe delivery."
    I've heard that line before. I think we all know how that can end..
    mhardy6647 Posts: 35,562
    There are folks who know how to pack...
  • simoes
    simoes Posts: 71
    My wife would toss me onto the curb if I spent 1.5k on a used amp! She's been begging for a louis vuitton purse for 5 years and would utterly lose her ****. What about the Monolith 3X? It's priced around 1k.
    I do wish I'd have taken "unboxing" photos of the preamp I recently bought. It was impressively packed. Overpacked, even -- and I pack for survival.
  • rooftop59
    simoes wrote: »
    Three of the 200 WPC monoblocks from outlaw are $800 shipped, I would get those over the monoprice personally although I think they are both manufactured by ATI?!?
    Either way, you better buy your wife that purse with the savings if you know what’s good for ya...
    Game Room 5.1.4:
    Bedroom 2.1
    gudnoyez Posts: 8,223
    A31 gets my vote, mine runs my fronts with authority.
  • simoes
    simoes Posts: 71
    Just pulled the trigger (without wife's knowledge of course) on three monoblocks. I think its great bang for your buck!
  • simoes
    simoes Posts: 71
    Hey Rooftop, in a different thread, you recommended adding the VTF-15H MK2 Subwoofer. The thing is a beast so I was wondering if it would create a problem sitting next to the Optoma P1 ultra short throw projector. The projector will be sitting on a cabinet about 20 inches from the wall. I haven't experienced a sub of that size so do you think it will vibrate the **** out of the projector/stand and 120" projector screen mounted on the wall?
  • rooftop59
    simoes wrote: »
    I have the smaller but still potent HSU VTF 2.5. It doesn’t vibrate anything but @mrloren has a bigger one maybe he can chime in?!?
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,487
    simoes wrote: »
    I have the VTF3-MK5 yes it can shake and rumble or be a tame roar. Great sub for the price. I have most of the small mantel stuff glued down as it was falling off. It does put out bass you can feel
    As for putting it close to the projector, you might be ok. I'd call HSU they won't try to upsell you
    My TV is about 5' away from the sub. The TV doesn't shake or vibrate at all.
  • simoes
    simoes Posts: 71
    Can the CSi A6 handle the 200 WPC monoblock? I ask that because Outlaw under rates the WPC.
    I think I'm going to go with the VTF3-MK5 over the VTF-15H MK2. They have very similar specs/performance, but the VTF3-MK5 is a bit cheaper (better value I think). Let me see what boxing day brings...
  • BlueFox
    BlueFox Posts: 15,250
    Basically any decent stereo speaker can handle any amplifier power. Only a few watts are necessary to achieve good sound. The additional power is used for musical peaks lasting for a millisecond or two.
  • Nightfall
    Nightfall Posts: 10,083
    Peaks? What peaks? Modern music rides that brick walled borderline.
    afterburnt wrote: »
    Village Idiot of Club Polk
    audioluvr Posts: 6,079
    Ya! Watts don't mean anything if it sounds like carp!
  • mrloren
    simoes wrote: »
    Yes the CSiA6 can take that Outlaw monoblock easy. I drove my old CSiA6 with an Emotiva XPA3G3 till I got the LSiM. The Emo is rated @ 275 watts.
    For the VTF3 over the 15H. They both use the same amp and driver, difference is the 15H is a lot bigger and will have a tad more low end. I like HSU subs but you might want to call SVS and see if any PB12-NSD are left. Two of those would be great.
    audioluvr wrote: »
    1000% agree there. I'd take a 20 Watt class A any day.
  • gp4jesus
    gp4jesus Posts: 2,025
    simoes wrote: »
    When those Outlaw monos “hit their stride” you’ll be in pain, my friend! Besides quality WPC don't matter if you “keep it clean.” My A6‘s config has ~350 on tap - I sleep well😊. OTOH, if you watch a lot of action adventure flicks, you need the “juice.”
    A couple of side notes: have you considered some dedicated power to feed all those high-powered toys? I’d say at least 3 20As plus a power conditioner for the TV, blu-ray, and pre/pro/AVR. Finally, you haven’t mentioned how much space you tryin’ to fill.
    Merry Christmas! Tony
    *all connected w/Premiere ICs
  • simoes
    simoes Posts: 71
    gp4jesus wrote: »
    You guys sure can bankrupt a guy in seconds! I was going to use the 200WPC monoblocks to power the front three and my Yamaha AVR (105 WPC) to power the surrounds and rears. Was then going to throw in the VTF3-MK5 or VTF-15H MK2 (see after boxing day) to severely annoy the entire household with my action movies. All this will be hooked up to a Optoma P1 Cinemax UST projector (120" screen) and you're still suggesting that I need more?? :# I have a power bar with a fuse in it lol
    BTW - I don't use Blu-ray or UHD players - I have an extensive library of over 2000 Blu-ray/UHD Remux rips on my computer which I will network with the projector.
    The room is about 16x13 but open to the entire basement - not a typical room with 4 walls.
  • mrloren
    Hahaha they need a disclaimer on this site. "We will help spend all your money".
    The above is very true. I've seen post where the say they have a grand budget and wind up dropping $5k.
    Stick in your budget, The 3 monoblocks and VTF3 will do you just fine. Maybe add another VTF3 next year
    For AC power, it is nice to have separate circuits @ 20A, I run all my gear on a 15A as adding another circuit would cost too much. I've never tripped the breaker.
  • simoes
    simoes Posts: 71
    Another question...
    I’ve always heard buy the biggest speaker you can afford. With that in mind, is it better to keep my A7s with the 200 WPC amp or would it be better to return them for the A9s. Would the same Amp provide them with enough power to take advantage of the bigger speaker?
  • rooftop59
    simoes wrote: »
    Another question...
    If this is mainly for HT I would use the extra money for the sub(s) and keep the A7s...
    Game Room 5.1.4:
    Bedroom 2.1
  • rpf65
    rpf65 Posts: 2,127
    You were worried about the VTF 15 shaking your projector, and your thinking about A9’s for even more bass?
  • simoes
    simoes Posts: 71
    rooftop59 wrote: »
    Only used for HT. Ok, I’ll keep the A7s. I appreciate everyone’s feedback and comments. It really speeds up the learning curve big time...
    I did a quick search for power conditioners and I can see there are a million different types ranging from $40 to thousands haha
  • simoes
    simoes Posts: 71
    rpf65 wrote: »
    I figured, if that huge monster didn't shake the projector, what's a couple of 7 inch drivers going to do lol
  • simoes
    simoes Posts: 71
    rooftop59 wrote: »
    Going back to the A7s vs the A9s lol I just checked and the price difference on boxing day is $120+tax between the two? Great deal on the A9s! Wouldn't it be worth while to get them? My only concern is the monoblock not being able to power them properly?!? If that's the case, I'm not going to invest more $$$ on amps...
  • gp4jesus
    @simoes: your “space” is 16 X 13 but the “room” is much larger. Bigger speakers favor bigger spaces but bigger isn’t always better. Approximate distance to your LR?
    I have a lot more I could say but others have kinda said it so instead I’ll expand on Mrloren’s post (copied from something I posted earlier today): you’re on a journey, that more than a few of us started years ago*. Decide what defines your system as complete. Consider all info w/the end & your wallet in mind. If you assemble your system like you should eat - slowly, one bite at a time, your patience will reward you.
    *me, over 11 years ago and I’m still not finished but that’s for another day.
    Many of us didn’t get where we are overnight* and neither will you - took me well over a year before I finalized my LR having had my existing CC & surrounds as above So take ❤️ by stepping slowly. That will prevent the expensive frustration of regrettable decisions.
