Additional Turntable - Denon DP-59L
Found a Denon DP-59L in great shape and the 120 volt version so I decided to get it. Seller has all the original packaging down to the tag that hung on the head shell.
I am researching what cartridge to use. Since I have a SoundSmith MIMC on the VPI I would like to go in a higher output direction. If you have an suggestion please pass them along.
Once I get it and have it setup I will get more pictures.
2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
  • dromunds
    dromunds Posts: 10,176
    If you could find a nice used Denon DL-160 it’s a bang for the buck HOMC that sounds good. One of my buddies had Soundsmith re-tip one that had a bad stylus and he also liked that quite a bit. I have a Denon DP-72L table that I like a lot. I had Soundsmith re-tip an SAE 1000e which is a re-labeled Coral 777 I believe. Very nice. But it’s a low output MC, although I think they may have made HOMC.
  • jdjohn
    jdjohn Posts: 3,459
    I've read good things about the newest Hana offerings. They have both low and high output MC with elliptical or Shibata tips. If vintage is a consideration, options abound...dromunds has hit on a few good ones already.
    FWIW, vintage Grace F9 is an excellent MM choice. Soundsmith makes a few different drop-in replacement stylii for the F9, which says something.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    tratliff wrote: »
    Great looking Deck!!! Congrats!
  • LoStrings
    I have used one of these tables for years, and it is my Holy Grail table...I use a Denon DL-103 LOMC cartridge, with the "S" arm, and it is a fantastic combination.
  • schwarcw
    schwarcw Posts: 7,360
    edited December 2019
    I have had a DP-59L for seven years now. I got it from long time member and the SRT King ESavinon at Polkfest 2012. It is a destination piece. I use the Denon DL-103R with the SoundSmith upgrades with a contour diamond and ruby cantilever potted in a Zu headshell (fully nuded). I use a Parks Budgie SUT. A great sounding combo! Some cartridge pics.
    Carl
