MagniFi-Max Sync Problem
LeeSoFL
A number of posts appeared regarding sync problems with the sub and/or surround speakers.
Are these on units that hadn't had the problem before, and now suddenly does? The update 115 has been around for several months, so it seems odd that it would crop up out of nowhere. Any comments on this issue is welcome.
With me it was right from the start... I only know my devices with version 115. Never tried it with an earlier version.
Mine was after a power reset. Which leads me to believe that the WiFi connector in the subwoofer is too fragile. If flipping the breaker causes the card to blow then it needs to be re-engineered.
