800va Dreadnaught with case and cables
TroyD
TroyD Posts: 13,124
edited December 2019 in For Sale (FS) Classifieds
I purchased this recently and haven't even opened it.......
Couple of reasons, I acquired a pair of CRS+'s but they are blade/blade and the serial #'s are not compatible and they are still lying dormant in the stereo room (I've got to sort out some stands).......and my grandiose plans to sell off a bunch of stuff and acquire a pair of 2.3tl's hasn't really gained any traction.
So, rather than this just linger indefinitely......I'm going to offer it up for sale.
Price is $225 shipped in the lower 48.
I'm partial to USPS money orders....not a PayPal guy. It is replete with suckiocity.
BDT
Here is the original description:
For Sale is my 800va Avel-Lindberg Dreadnaught in an aluminium case with a small sheet of sound dampener. The case holds the torrid very tight as it is barely bigger than the torrid with no need for a bolt to hold it in place. This is plug and play. It is set up to use the Pin/Blade socket (RCA Pin) and the negative binding post on SDA's. If you only have one set of binding post on your SDA's just switch the speaker end banana to a spade if needed and you are good to go. I've used this for about 2yrs and it works very well. The cable appears to be an Audioquest cable and it well built. I used it for about 6mo. before I built my own so all my cable matched my speaker cable. This in case you do not know is perfect for NON-COMMON ground amps and MONO BLOC bloc amps. This also works VERY well on common ground amps for much better sound than just the interconnect cable alone.
  • gyosa
    gyosa Posts: 770
    Have any pics ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    F1nut Posts: 52,296
  • gyosa
    gyosa Posts: 770
    Thanks Jesse !
    Not sure I need it , but what will it do for my 1c’s and Parasound A21 ?
    They’re stock , with the exception of new tweeters ...
    Bk
    F1nut Posts: 52,296
    gyosa wrote: »
    Thanks Jesse !
    Bk
    The Dreadnought improves the sound with common ground amps verses a regular SDA cable.
    pitdogg2 Posts: 27,767
    gyosa wrote: »
    Thanks Jesse !
    Bk
    Mo'better sound. The dreadnaught's are much better than stock IC cable.
  • TroyD
    TroyD Posts: 13,124
    El Bumpo....
  • muncybob
    muncybob Posts: 3,302
    So, this is a no go with blade/blade on 2Bs?
    Yep, my name really is Bob.
  • TroyD
    TroyD Posts: 13,124
    2B's must be: Left Channel #14115 or greater, Right Channel #14124 or greater
  • TroyD
    TroyD Posts: 13,124
    Sexy!
    I may just have to rub my dingus on this just because.
    BDT
  • verb
    verb Posts: 10,176
    TroyD wrote: »
    Sexy!
    BDT
    That'll cost ya about a 50% reduction in price! :smile:
    F1nut Posts: 52,296
    TroyD wrote: »
    Sexy!
    BDT
    I would.
  • TroyD
    TroyD Posts: 13,124
    HAAAAAAAARRRRRRRR!
  • fafaafooie50
    If this is for sale still please DM me.
    txcoastal1 Posts: 13,519
    Forgive Ivan he forgot to bump TroyD
    @TroyD
    My bad
    Please be patient Troy is a busy man and it may take some time. AFAIK it is still for sale.
  • TroyD
    TroyD Posts: 13,124
    Sorry I've been out of touch guys....a TON of stuff going on in life. No excuses but just is what it is...
    I did sell this, sorry about that!
