Command Bar Remote Reset?
tnahas
My remote stopped working recently, thought it was batteries but not. Any way to pair, sync, or reset remote?
My remote just did same thing, waiting on an answer
Were you able to get this resolved? Having the same issue now.
I have the same problem. Before changing the battery the remote was acting erratically. If I pressed the volume buttons the sound would mute. I would have to manually shut off bar and restart.
Anybody have any luck with remote mine completely stopped working after changing batteries
my remote has quit working also....I don't see any solution on this page
Send an email to: kim.jasper@soundunited.com and he will help.
2023 and still having same issue and no solution
