Silver IC's
Anyone here have any experience with these? I need a set for my new tube pre.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/323549736534
    audioluvr Posts: 6,079
    Good point
    edited October 2019
    Well I'm still needing a 1 m long set With male XLR x RCA. My B&K Ref pre has been acting up so I sent it to Goodwill. I guess I could send my silver eclipses back to Wirewold for retermination. That would be cheaper and faster than sending my amps in for rebuild
  • Unknown
    edited October 2019
  • delkal
    delkal Posts: 764
    edited October 2019
    The interconnects appear to be shielded but it is not clear which end of the shield is grounded. Every shielded cable needs to have an arrow.
    You want to have the shielded end attached to ground on the component side that is doing the output. The other side should not be attached to the shields outer wrap.
    audioluvr wrote: »
    Or buy balanced to RCA adapter?
    https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m4084.l1313.TR11.TRC1.A0.H0.Xbalance+to.TRS0&_nkw=balance+to+RCA+adapter
    Ya, I looked at those but I would need a male XLR to male RCA adapter which they don't make and I'm trying to minimize extra crap in the signal path so...
