points of first reflection
marvda1
marvda1 Posts: 4,965
edited October 2019 in Speakers
you can enter inches, cm, meters, feet.
http://www.acoustic.ua/forms/calculator4.en.html
Puritan PSM156
  • pawelmwo
    pawelmwo Posts: 137
    Thanks for sharing. I'd probably need special help with our room arrangement. It's got some of the big acoustic no no's. Open floor plan leading into the kitchen, vaulted ceilings, a glass cabinet, a fireplace. The room is rectangular but the speakers are in the shorter side down the middle. Speakers about two feet off the wall and so is rear couch. Honestly after running Audyssey the improvements are very notable. However sadly, most acoustic treatments would not get the wife approval factor :) Next house might need a dedicated theater room.
    I usually don't worry too much about that either, unless it's obvious like one side next to a big open area for the sound to bleed out into.
    Normally, we set up systems in a room with boundaries, for critical listening anyway. Casual listening isn't going to be bothered by first reflection points anyway.
