Polk sda tweeter bad
Hi, im new to thus forum. Just picked up some sda 1's and the right tweeters seem bad. Is it a hard replacement and if anyone on the forum has the sl000 gerys i woild be interested.
Thanks and glad to be a part of this forum
    pitdogg2 Posts: 27,917
    edited October 2019
    Right tweeters? Do you have the SDA cable hooked up? Without using the SDA cable the outside (dimensional) tweeters are not going to work. Most of us disable them either by taking out the fuse (if your set has them) or by removing the hook up wires and taping them up so the do not short.
    Without using the cable the dimensional woofer also is disabled.
    Welcome to the club
  • verb
    verb Posts: 10,176
    PolkK wrote: »
    Welcome! Ivan is correct as always :smile: Post some pics!
  • PolkK
    PolkK Posts: 10
    Thanks for the quick response. I do have the cable hooked up and tried switching tweeters between then speakers and they are defintely not functioning. Rooms im disarray but heres the first pics.s2uqyral0k4a.jpg
    Those SDA1b or are they SDA1c? Either way the sl1000 are not the correct tweeters. Is the interconnect a Blade/blade or Pin/blade.
    You need to give more details and information so we can help you better.
    1. The tweeters are not functioning in either speaker.
    2. You moved known good tweeters into the speaker and they do not fuction either?
  • PolkK
    PolkK Posts: 10
    Yea i know they are not but it was the only pair of spares i had on hand to try and switch out and when they are plugged in they work. No idea on the model the serial is basically gone.
    Lol i know la it looks like a **** hole right now hahahaha
    F1nut Posts: 52,406
    Those are 1B's. The silver faced SL1000 tweeters are the wrong ones. There is a polyswitch (thermal reset device) on the crossover for tweeter protection that has likely gone competely bad preventing any signal from reaching the tweeters.
    SDA speakers should be 5 to 6 inches off the back wall, NO TOE IN, 6 to 8 feet apart and 3 feet from any side wall.
    You're going to kill that receiver if you leave it on the carpet with no open space above it. It, like you, needs to breath.
  • PolkK
    PolkK Posts: 10
    Will take a pic of the sda cable inputs when im out of work
    It is easy to tell if you pull your drivers. SDA1b had all MW6509 drivers. SDA1c had 2 stereo MW6510 and 2 dimensional drivers MW6511. Stereo drivers are inside drivers and dimensional are outside drivers.
    OK so you have not really answered questions clearly. So I'm just going to state you have two blown tweeters on one speaker. Where are you located? What are you running them with, Receiver or amp ?
  • gyosa
    gyosa Posts: 770
    I’m surprised that receiver hasn’t caught on fire yet !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • PolkK
    PolkK Posts: 10
    Yes the speaker with the sl1000s has both blown tweeters. I am running them with a parasound a23. Im located in nevada. I am a total newbie so sorry if the info is not complete.
  • PolkK
    PolkK Posts: 10
    The receiver on the ground is just an extra one i have cause i couldnt afford storage anymore.
  • PolkK
    PolkK Posts: 10
    PolkK wrote: »
    Do the SL1000 tweeters work in the speaker? Newbie or not you are not helping with half answering questions and mostly incoherent posts as to the questions asked.
    So sans complete answers to question asked I will go with F1nut and say if the SL1000 tweeters are not working in that speaker then it's because the polyswitch is no good.
  • PolkK
    PolkK Posts: 10
    The sl1000s are working perfectly. The sl2000s that it came with are not working at all.
  • PolkK
    PolkK Posts: 10
    With it*
  • PolkK
    PolkK Posts: 10
    I swear im trying my best to answer whats asked but besides loving the sound of a polk i know little to nothing about speakers.
